spinner paint scheme
Old January 24th 05, 11:47 PM
jls
" jls" wrote in message
"Dick" wrote in message
. com...
In the past. someone had provided a formula
for painting a corkscrew on a prop spinner but I seem unable to find it.
Can anyone help as I'd like to paint my new spinner?
Thanks, Dick
search with barber pole effect spinner
Welp, try googling Brian Whatcott who provided the barber-stripe to Pianome.
That should get you there. I think I'd like to do that barber-pole stripe
thing too.
Old January 27th 05, 09:58 PM
Pianome
I am the one that posted the original question...Below is the question and
response I received from Brian W. The only difference was I used a "dry
erase" pen instead of tape. I hand painted the stripe, then let it dry,
erased the pen mark, and painted the remainder. Worked great!
Also a picture of the finished product!
http://home.mchsi.com/~pianome2/leftside.jpg
Does any of you old-timers, or young'uns have an idea of how to put a
barber-stripe on a spinner? I'm having a heck of a time putting tape on and
keeping it even. Also what size stripe would look best? It is a 9" diameter
by 12" tall.
Disclaimer: I have not done this.....
Spray spinner with body color (white or yellow)
Measure four points on the base of the spinner, evenly spread at 90
degrees from each other, i.e. 7.069 inches apart around the base
circumference.
Draw four lines to the apex of the spinner.
Along the first line, mark intervals of one inch from base towards
apex. That's 12 marks. Move to the next line: starting 1/2 inch from
the base, mark intervals of 1 inch towards the apex. There will be 12
marks
Move to the next line: starting at the base, mark intervals of 1 inch
there will be 12 marks
Move to the last line: starting 1/2 inch from the base, make 1 inch
intervals.
Using THIN (1/8 inch) masking tape, lay a spiral line forward of the
base point of line one, forward of the first mark on line two (1/2
inch forward), forward of the first mark on line three (1 inch from
base), forward of the 2nd mark on the fourth line (1.5 in from base)
back tothe second mark on line 1 at 2 inch from base
progressing 1/2 inch per line towards tip.
Then...
Using thin masking tape, lay a spiral of tape aft of the base point of
line three, aft of the 1st mark on line 4 (1/2 inch from base)
aft of the first mark on line 1 (1 inch forward from the base).
Fill in the ragged mask area between the two smooth edges.
Adjust the apex end for a pleasing center pattern.
Spray stripe with contrast color yellow for white body, black for
yellow body.
Remove masking tape.
If I have described the markup correctly, this will give a one inch
wide yellow spiral on 1 inch wide white spiral.
(or a 1 inch black and 1 inch yellow spiral)
Brian W
Paint Stripper? PETER H. OUELLETTE Home Built 9 November 30th 04 06:12 PM
One coat paint for aluminum? [email protected] Home Built 10 September 17th 04 07:01 AM
spinner fab Dick Home Built 5 April 23rd 04 02:26 AM
Choice of Paint for use over Copper foil Antennas Charlie Precourt Home Built 1 December 2nd 03 02:51 AM
Velocity Paint scheme Ezaviator Home Built 0 July 31st 03 04:09 AM
