Alternate minimums same as forecast weather
Old April 10th 05, 07:55 PM
Ron Natalie
Bob Gardner wrote:
You are not required to go to your filed alternate if you cannot get into
your destination; ATC has no idea of what you filed as an alternate. What is
the problem??
The role of an alternate is to determine your minimum fuel requirements more
than any other practical use.
Old February 9th 06, 05:32 PM posted to rec.aviation.ifr
Default Alternate minimums same as forecast weather
So is this all ok?
Stan
Usually yes. Keep in mind, your FILED alternate does not have to be the
actual field you divert to. You simply have to have "ON PAPER" a field
that is within your capabilities (fuel) and specified weather conditions.
There may be DOZENS of other fields nearby/in range that are safe and
useable, but are unable to be listed as legal alternates.
I say usually. A big part of this decision is what the weather is across
the region. Is the entire region socked in low/hard or is there a
localized weather phenom that will move on/clear up/etc?
From a legal standpoint, its good to go. From a safety standpoint, its
all relative. If it doesnt worsen, its just as safe as any other IFR
flight to near minimums. If the whole region is blanketed by low clouds
you may shut yourself out.
With regards to your example (assuming ILS our at Carlsbad), as a
general rule, I would want to have an alternate that had a working ILS
with good precision minimums available to me, so that there is a large
margin between the higher "alternate" minimums and the actual minimums
that I will fly the approach to.
Dave
Old February 9th 06, 06:41 PM posted to rec.aviation.ifr
I always like to have a very good VFR alternate I can find
with nothing more than a working compass and clock. I
probably would not go to a filed alternate unless I had a
total radio/electrical failure. Often the airport at my
destination with the lowest minimums isn't the airport where
the cars are parked. Also, often in the foggy season, the
entire plains and Mississippi Valley are at a steady and
stable 400 feet and 1-2 miles in fog and stratus. The
nearest airport with alternate minimums (600-2 or 800-2) may
be several hundred miles away, which means that a big
turbo-prop or jet is needed just to fly from Wichita to
Kansas City, since the alternate is beyond fuel range.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Dave S" wrote in message
et...
| So is this all ok?
| Stan
have to be the
PAPER" a field
weather conditions.
are safe and
weather is across
there a
standpoint, its
other IFR
by low clouds
Carlsbad), as a
working ILS
there is a large
actual minimums
| Dave
Old February 17th 06, 11:24 PM posted to rec.aviation.ifr
File what you have to, fly what you need to. Let's not try to solve
decision making issues with regulation.
-Robert
Old February 21st 06, 04:22 PM posted to rec.aviation.ifr
This issue is raised in AIM 5.1.9(b) anyway:
b. The FAA has identified three possible situations where the failure
to plan for an alternate airport when flying IFR to such a destination
airport could result in a critical situation if the weather is less
than forecast and sufficient fuel is not available to proceed to a
suitable airport.
1. An IFR flight to an airport where the Minimum Descent Altitudes
(MDAs) or landing visibility minimums for all instrument approaches are
higher than the forecast weather minimums specified in 14 CFR Section
91.167(b). For example, there are 3 high altitude airports in the U.S.
with approved instrument approach procedures where all of the MDAs are
greater than 2,000 feet and/or the landing visibility minimums are
greater than 3 miles (Bishop, California; South Lake Tahoe, California;
and Aspen-Pitkin Co./Sardy Field, Colorado). In the case of these
airports, it is possible for a pilot to elect, on the basis of
forecasts, not to carry sufficient fuel to get to an alternate when the
ceiling and/or visibility is actually lower than that necessary to
complete the approach.
2. A small number of other airports in mountainous terrain have MDAs
which are slightly (100 to 300 feet) below 2,000 feet AGL. In
situations where there is an option as to whether to plan for an
alternate, pilots should bear in mind that just a slight worsening of
the weather conditions from those forecast could place the airport
below the published IFR landing minimums.
3. An IFR flight to an airport which requires special equipment; i.e.,
DME, glide slope, etc., in order to make the available approaches to
the lowest minimums. Pilots should be aware that all other minimums on
the approach charts may require weather conditions better than those
specified in 14 CFR Section 91.167(b). An inflight equipment
malfunction could result in the inability to comply with the published
approach procedures or, again, in the position of having the airport
below the published IFR landing minimums for all remaining instrument
approach alternatives.
Old February 21st 06, 09:50 PM posted to rec.aviation.ifr
I would not like to see the FAA change the rules to handle
these exceptions, but a good pilot will note the conditions
and always plan for the worst. Even in perfectly clear
skies, Aspen is still just ONE runway. If there is a gear
up landing, you will go to an alternate.
If the weather is IFR at 800-2 and you're in the soup when
the airport equipment fails, you'll go to an alternate.
Whether that alternate is 10 miles away or 800 depends on
where you are flying and how much fuel you can carry.
James H. Macklin
ATP,CFI,A&P
some support
the failure
destination
weather is less
proceed to a
| suitable airport.
Altitudes
approaches are
CFR Section
in the U.S.
the MDAs are
minimums are
Tahoe, California;
of these
basis of
alternate when the
necessary to
have MDAs
In
for an
worsening of
airport
equipment; i.e.,
approaches to
minimums on
than those
equipment
the published
the airport
instrument
Old February 21st 06, 10:20 PM posted to rec.aviation.ifr
800-2 at Aspen? Not for me!
If KASE flirts with 2000-3, I'm going to my alternate.
Not much different for Eagle County, either.
I've diverted to Grand Junction and Montrose several times.
"Jim Macklin" wrote in message news:UWLKf.102996$4l5.42576@dukeread05...
.... Even in perfectly clear
James H. Macklin
ATP,CFI,A&P
Old February 21st 06, 10:45 PM posted to rec.aviation.ifr
Did not mean Aspen at 800-2, 800-2 is a flat land
non-precision alternate airport for filing minimum. Note
the term, minimum, you can always select more, higher.
Personally, I would not do Aspen unless the weather in the
area was 2,000 feet above the peaks, the only times I've
been in there, it was either clear or high cirrus, beautiful
place under those conditions.
Each of the conditions listed was intended to be independent
of the other, sorry if I confused you.
Just to refresh the pilots out there;
ALL IFR flight plans require an alternate and the fuel
required to get there, unless
the weather one hour before and after ETA, is forecast to be
2,000 and 3. Any airport listed as an alternate must be
forecast at the time of arrival to be 600-2 with glide slope
and 800-2 without. [or very good weather if no approach].
If the destination does not have an approved approach an
alternate is always required.
The penalty for having to file an alternate is you have to
have the fuel [weight] and the penalty for not having an
alternate, filed or not and the fuel to get there is
possibly death.
James H. Macklin
ATP,CFI,A&P
some support
"John R. Copeland" wrote in
message
James H. Macklin
ATP,CFI,A&P
making the transition from renter to owner part 2 (long) Journeyman Piloting 2 April 15th 04 10:19 PM
Personal Weather Minimums FryGuy Piloting 26 December 9th 03 06:09 AM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
Flight plan Hankal Instrument Flight Rules 15 October 11th 03 08:03 AM
Airspace / Weather Minimums Rose Goetsch General Aviation 0 September 24th 03 08:45 PM
