![]() "Ben Jackson" wrote in message ... On 2005-04-10, Matt Barrow wrote: "Greg Esres" wrote in message ... Our flight school has received a C182 with a G1000. The checkout requirements are going to be 5 hours VFR and an additional 5.6 hours for IFR pilots. Does anyone find this excessive? To fly a new generation $350,000 aircraft, no. Considering the difficulty in scheduling rental aircraft for real travel, I think a 10+ hour checkout is going to keep people away in droves. If not that, the $216 an hour will. The new avionics should be mastered on the ground with a simulator (or a real unit with an external power source). There's no point in turning the hobbs meter until you know how to run all the gadgets. A competent instrument pilot should be able to get into the plane after studying and do enough approaches to be comfortable in an hour or two. Some, especially the computer savvy could probably do it in that time. I got a 182 checkout (the first high perf airplane I flew) in about 1.3, which included stalls, steep turns, and landings/go-arounds in every configuration. We didn't take off until I had correctly rehearsed the power and engine management on the ground. That's pretty unusual. Usually 1.3 hours is hardly enough time to run but about 4-5 touch and goes. I transitioned from mainly a T182 (rental) to a T210 (ownership) and my insurance company wanted 10 hours of dual. The FBO/School that trained me wanted five hours dual to fly the T182 before solo after learning in a 172. So I would tend to think that anything more than (rounding way up) 5 hours would just be milking the renter. Or their paranoid (justifiably?) insurance carrier. If they can't do it in 5 hours then they have other issues with currency/proficiency but that shouldn't be reflected in the FBO minimums. Probably, but I suspect that, as someone else pointed out, it's probably a matter of insurance. It's the $216 an hour that I found bizarre. |
Matt Barrow wrote:
"Ben Jackson" wrote in message I got a 182 checkout (the first high perf airplane I flew) in about 1.3, which included stalls, steep turns, and landings/go-arounds in every configuration. We didn't take off until I had correctly rehearsed the power and engine management on the ground. That's pretty unusual. Usually 1.3 hours is hardly enough time to run but about 4-5 touch and goes. Do you fly a 20 mile downwind or something? ![]() |
![]() "Chip Hermes" wrote in message oups.com... Matt Barrow wrote: "Ben Jackson" wrote in message I got a 182 checkout (the first high perf airplane I flew) in about 1.3, which included stalls, steep turns, and landings/go-arounds in every configuration. We didn't take off until I had correctly rehearsed the power and engine management on the ground. That's pretty unusual. Usually 1.3 hours is hardly enough time to run but about 4-5 touch and goes. Do you fly a 20 mile downwind or something? ![]() Are you shooting visual or instrument approaches to check out the new gear? Also, on the Hobbs, just start, run-up and initial taxi can take 10-12 minutes. |
C182 - Intermittent Alternator | WinstonCup | Owning | 9 | November 12th 04 12:22 AM |
c182 fuel burn | Rob Timmerman | Owning | 18 | July 7th 04 03:46 PM |
C182 Glass Panel | Scott Schluer | Piloting | 15 | February 27th 04 03:52 PM |
Garmin G1000 | Foster | Owning | 2 | July 20th 03 06:45 PM |
