ATC Altimeter Settings
Old April 11th 05, 11:19 AM
One is subjective, the other is objective. What some people think is
long, others would say is short. Longer or longest can be measured,
howeever.
Some people would say this thread is long. Some would even say too
long.
It is certainly longer than it needs to be, and a shorter thread would
have been bettter.
But it's not the longest thread I've ever seen, nor is it certainly
the shortest.
But then, my memory is short. I often wish it were longer.
On 11 Apr 2005 06:15:53 GMT, Stan Gosnell wrote:
"Chris" wrote in
ink.net...
"Chris" wrote in message
Incorrect, that's longer, i.e. there are two long runways but
one is longer than the other, or two short runways with one longer.
Wouldn't the longer of the two be the long one?
Nope the longer of the two would be the longer one. They could both be
long ones, but only one can be longer.
The longer of the two could still be short. If the longer was only 500',
I would still call that short. It's longer, but short. Or you could say
the other one was the shorter one. But you don't have to call me Ray.
Old April 11th 05, 02:27 PM
Icebound
long.
have been bettter.
the shortest.
Your memory is neither long nor short. Memory has no length. It simply has
purpose, the operation of remembering.
Time, arguably, has length. It is true that memory may be able to operate
only on the recent past time-span, and not on the long past time-span as
well ....but what is worse: even if it can operate on a long past time-span,
that operation may be innacurate.
Old April 11th 05, 03:38 PM
On Mon, 11 Apr 2005 09:27:37 -0400, "Icebound"
There is no time in a any sense that can be expressed in length.
Time is only a word we use for measuring change.
Things just exist. Just becaause a rock in space has spun around
another rock n times does not imply some "length".
You are not older than you were 30 years ago. Your cellular structure
has simply changed.
Old April 11th 05, 08:07 PM
Icebound
*** A great civilization is not conquered from without until it
has destroyed itself from within. ***
- Ariel Durant 1898-1981
time-span,
has simply changed.
Time (sic) to re-requote one of the more astute observations in this
sub-thread:
"It is certainly longer than it needs to be, and a shorter thread would
have been better."
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 02:01 PM
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 07:58 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
Altimeter experience HankC Piloting 2 July 25th 03 09:43 PM
