Brake adjustment on the 2-33
Old April 12th 05, 04:40 AM
GM
5Z wrote:
You should be able to remove the lever and rotate it on the spline in
order to get it back to a better angle.
I tried that. There is no spline. The lever and the cam seem to be made
out of one piece.
And yes, if the cable is in line with said lever, it does not matter
how much I tighten the turn buckle.
I guess it all comes down to the drum diameter. I have the sneaky
suspicion that someone in the past bored them out way too big.
Again, does anyone have a number for the maximum permissible drum I.D.?
Uli Neumann
Old April 12th 05, 01:40 PM
Drum diameter is one possibility. As is that the cam on the arm, or the
portion of the brake shoe that touches it, is worn beyond useful life.
UH
Old April 19th 05, 07:05 PM
Ian Forbes
If the drum has been machined over diameter, a brake specialist should
be able to measure the drum and fit overthick linings on the shoes to
match.
(That may explain why you have "worn" shoes with plenty of wear lining
left on them).
Ian
SZD-55 Wheel Brake Adjustment WDM Soaring 2 January 20th 11 09:25 AM
BRAKE FLUID Ventus B Soaring 9 October 17th 04 07:25 PM
Cobra Brake Parts or Axle WDM Soaring 1 October 11th 04 05:09 AM
Building the Po' Boy Bending Brake Veeduber Home Built 14 March 1st 04 06:15 PM
Brake caliper flange Stealth Pilot Home Built 5 July 7th 03 04:19 PM
