fwiw, I'm a fairly high time pilot (IFR). I need carb heat a lot more
than pitot heat in VFR. At run up on a normally carburated engine if you don't get an RPM dropoff when you pull the carb heat on, you don't go. There's no such test for pitot heat (although I will tell you if I'm going IFR I turn it on for a while when first in the cockpit, then make sure it's warm during the walk around. |
Yup, even if you aren't planning on using it, it is nice to know what works
and what doesn't before you leave the ground. -- Hello, my name is Mike, and I am an airplane addict.... "Tony" wrote in message ups.com... fwiw, I'm a fairly high time pilot (IFR). I need carb heat a lot more than pitot heat in VFR. At run up on a normally carburated engine if you don't get an RPM dropoff when you pull the carb heat on, you don't go. There's no such test for pitot heat (although I will tell you if I'm going IFR I turn it on for a while when first in the cockpit, then make sure it's warm during the walk around. |
28 volt pitot heat | B2431 | Home Built | 15 | April 17th 04 03:25 PM |
pitot heat question | K. Ari Krupnikov | Instrument Flight Rules | 7 | December 11th 03 01:51 AM |
Pitot heat | Paul Mennen | Owning | 10 | November 6th 03 09:54 AM |
Pitot heat | Paul Mennen | Piloting | 10 | November 6th 03 09:54 AM |
Pitot Heat | Roger Long | Piloting | 12 | November 6th 03 02:01 AM |
