Home air band listening.
Old July 13th 03, 06:07 PM
10Squared
Rich Hare wrote:
I'd like to improve my air band listening at home. I'd like to be able
to capture ATC ground transmissions from an airport 15 miles away (DTW)
and ATIS from DTW and YIP (also about 15 miles). I'm in a two story
house in a typical suburban setting on ground about 200' higher than the
airports in question.
I'm going to install a base station antenna in my attic (outside is not
doable) and run coax down to the basement. Sometime later I may run it
into my den. I'd like to put a TV coax amplifier in the system to help.
Receiver will be my handheld, but later I might use an illegal
(transmitter) 360 navcom (Com 11?) if I can find one that works at a
giveaway price.
Questions:
- Anybody got a rig like this? Suggestions?
- Should I put RF amp up in the attic, near the antenna, or in the
basement, near the receiver?
- Any watchouts?
The signal is line of sight, so elevation is everything. I doubt you'll gain
anything from the RF amps. Instead, consider building a Yagi antenna for
the band you'll be listening on and point that toward the field.
Home aerial for an ICOM AC-A5? jls Home Built 14 December 14th 04 07:19 PM
Best Home Base Work Reynard Home Built 0 November 9th 04 04:37 PM
Free Volksplane to good home, located in Chino Hills CA Bryan Zinn Home Built 3 July 18th 04 02:55 AM
Home Inspection Listings Patrick Glenn Home Built 4 April 26th 04 11:52 AM
Home Builders are Sick Sick Puppies pacplyer Home Built 11 March 26th 04 12:39 AM
