"Dude" wrote: "Steve Foley" wrote in message ... Figure out what it would cost to pay to get it fixed, and what it would be worth after the repairs. Subtract the repair cost from the final value - that's what you should pay. If you do the work yourself, you should pocket the savings, not the current owner. That will get you the high end value. Another thing to do is factor in risk. In this case, Chuck and his buddies have less risk because they know the plane. However, the likely sales price is what someone else, who doesn't know anything about the plane other than what they can see or pay to find out, is likely to offer. The second method will get a low end, where they should probably start their negotiations. If the operator has been cutting corners on maintenance, you could be surprised at the kind of fleas hiding in that dog! I would expect worn gear trunions, old hoses, leaky fuel bladders, corrosion, a prop that needs expensive AD compliance, crazed glass -- just to name a few starters. -- Remove _'s from email address to talk to me. |
Orval is correct on the miscellaneous parts that will need attention -
corroded wheel hups cause @250 per half, hydraulic actuators about the same. There is a SB1006 on wing corrosion that requires that the tanks be pulled (might as well do that anyway to replace the hoses as they will be cracked by now). It's likely that Lycoming will insist that the engine core be junked on rebuild. VREF is 10-15% high. In pristine condition, I'd guess the plane might be worth $80K, but people who pay to put aircraft in pristine condition usually lose 50% of the cost of doing so. If you want a nice Arrow, buy one in which someone has already invested that premium. It NEVER pays to buy a project unless you can do virtually of the work yourself, and even at the cost of the parts will just about equal the gain in value. |
![]() On 9-May-2005, "Paul kgyy" wrote: VREF is 10-15% high. In pristine condition, I'd guess the plane might be worth $80K If you mean "otherwise pristine but with a run-out engine," then the $80K figure is probably too high. But if you can find a very clean Arrow III with the avionics described in this thread, including a Garmin 430, with a zero time or near zero time engine for $80K I would be stunned. II think it would sell very quickly for $10K more. -- -Elliott Drucker |
ORVAL FAIRBAIRN wrote:
In article , "Dude" wrote: "Steve Foley" wrote in message ... Figure out what it would cost to pay to get it fixed, and what it would be worth after the repairs. Subtract the repair cost from the final value - that's what you should pay. If you do the work yourself, you should pocket the savings, not the current owner. That will get you the high end value. Another thing to do is factor in risk. In this case, Chuck and his buddies have less risk because they know the plane. However, the likely sales price is what someone else, who doesn't know anything about the plane other than what they can see or pay to find out, is likely to offer. The second method will get a low end, where they should probably start their negotiations. If the operator has been cutting corners on maintenance, you could be surprised at the kind of fleas hiding in that dog! I would expect worn gear trunions, old hoses, leaky fuel bladders, corrosion, a prop that needs expensive AD compliance, crazed glass -- just to name a few starters. That's what I was thinking, and why to me the value of the plane would be $0. |
Fun weekend buying an Arrow (long) | Jack Allison | Owning | 44 | April 20th 05 12:29 PM |
Fun weekend buying an Arrow (long) | Jack Allison | Piloting | 45 | April 20th 05 12:29 PM |
Getting used to the Arrow...and I like it...a lot! | Jack Allison | Piloting | 37 | April 19th 05 03:56 PM |
Ongoing Arrow alternator/charging problem | Chuck | Owning | 6 | December 22nd 04 01:18 AM |
CF-105 AVRO Arrow etc. | Ed Majden | Military Aviation | 4 | February 22nd 04 07:00 PM |
