Dave,
Muchos gracias. I'll try that tonight. P3 |
Go to this page
http://www2.onlinecontest.org/validate.php FM Papa3 wrote: Dave, Muchos gracias. I'll try that tonight. P3 |
Thanks. Required a bit of troubleshooting to figure out why the DOS
shell was throwing an exception ("can't run 16-bit applications...") Got that sorted out as well. I always wondered if my knowledge of DOS commands would ever be useful again. Thank goodness for soaring... Anyway, it looks like it didn't work. Popped open the file in text editor after the DOS application successfully ran, but there are thousands of bytes of ASCII characters appended to the file. It sure doesn't fit the syntax of a G Record per the IGC specs. Is there a way on the OLC to validate a flight without going through a full submission (I tried, but can't find it)? SeeYou doesn't seem to have that utility (although I can't run help to RTFM, because the help process seems to also throw an exception). Oh, and the original cambridge VALI DOS programs won't work on this translated file. Editorial rant: I run a freakin' software development organization for a living, and I fly for fun. This is starting to look seriously like work. And, back to my original request, assuming I get this sorted out, has anyone created a simple script that will run on the pocket PC to do this in situ (on the Pocket PC)? |
That bunch of stuff appended to the file is the whole *.cai file,
including the security record, encoded into ascii text (base-64?). Just upload it to the OLC. Papa3 wrote: Thanks. Required a bit of troubleshooting to figure out why the DOS shell was throwing an exception ("can't run 16-bit applications...") Got that sorted out as well. I always wondered if my knowledge of DOS commands would ever be useful again. Thank goodness for soaring... Anyway, it looks like it didn't work. Popped open the file in text editor after the DOS application successfully ran, but there are thousands of bytes of ASCII characters appended to the file. It sure doesn't fit the syntax of a G Record per the IGC specs. Is there a way on the OLC to validate a flight without going through a full submission (I tried, but can't find it)? SeeYou doesn't seem to have that utility (although I can't run help to RTFM, because the help process seems to also throw an exception). Oh, and the original cambridge VALI DOS programs won't work on this translated file. Editorial rant: I run a freakin' software development organization for a living, and I fly for fun. This is starting to look seriously like work. And, back to my original request, assuming I get this sorted out, has anyone created a simple script that will run on the pocket PC to do this in situ (on the Pocket PC)? |
![]() David Leonard wrote: That bunch of stuff appended to the file is the whole *.cai file, including the security record, encoded into ascii text (base-64?). Just upload it to the OLC. Wilco. As an aside, I actually went to the FAI site and downloaded the zip file containing various CAI DOS utilities (conv-cam) which converts to ..igc format. It definitely creates a short G Record that looks "right" (ie a couple of lines); anybody know if this utility creates a file that passes muster with the OLC. |
No it does not pass the OLC security check. Thats why the OLC has you
tack the *.cai file onto the end of the *.igc file. About 2 years ago, it did, but no more. Papa3 wrote: David Leonard wrote: That bunch of stuff appended to the file is the whole *.cai file, including the security record, encoded into ascii text (base-64?). Just upload it to the OLC. Wilco. As an aside, I actually went to the FAI site and downloaded the zip file containing various CAI DOS utilities (conv-cam) which converts to .igc format. It definitely creates a short G Record that looks "right" (ie a couple of lines); anybody know if this utility creates a file that passes muster with the OLC. |
WTB: Sage Model B Netto Total Energy Box | November Bravo | Soaring | 0 | March 15th 05 03:10 PM |
Model Building (but not with plastic and glue) | [email protected] | Soaring | 7 | March 3rd 05 04:01 AM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
FA: 5 Airplane Model Kits - Bomber, Jet, Warbird | Disgo | Aviation Marketplace | 0 | February 22nd 04 05:00 PM |
FA: Bomber Plane Model MIB - Monogram 1/48 HEINKEL | Disgo | Aviation Marketplace | 0 | February 21st 04 02:40 PM |
