The curved side of the blade is called the "back" or "cambered side". The
flat side is called the "face" or "thrust side". The back usually doesn't get many nicks in it. AC43-13-1B change 1 has all the information you could desire about blending out nicks in your propeller, including limitations. You shouldn't repaint the blade without closely inspecting and repairing the nicks, You might paint over a developing crack. "canflyboy" wrote in : Hi All I'm repainting my McCauley Aluminium prop and was wondering if anyone can give me some guidance in regards to the little aluminums dings that occurred on the back side of the tip on the prop. These are tiny dings the prop has picked up over the years from sucking up debris while taxing. They vary from tiny pin pricks to small scratches, maybe .015" at the deepest and maybe about .05" inches long. I'm not sure if I should try and dress these out with a sander (grinder) because to get them all out, I'd be taking off some serious aluminium. Any tips on sanding would be appreciated. Thanks Eugene -- J Kimmel www.metalinnovations.com "Cuius testiculos habes, habeas cardia et cerebellum." - When you have their full attention in your grip, their hearts and minds will follow. |
guynoir wrote:
The curved side of the blade is called the "back" or "cambered side". The flat side is called the "face" or "thrust side". The back usually doesn't get many nicks in it. I get more dings in the back (the side facing the pilot) than I ever get in the front. |
The side facing the pilot is the face. The side away from the pilot is the
back, unless you fly a pusher. Ron Natalie wrote in m: guynoir wrote: The curved side of the blade is called the "back" or "cambered side". The flat side is called the "face" or "thrust side". The back usually doesn't get many nicks in it. I get more dings in the back (the side facing the pilot) than I ever get in the front. -- J Kimmel www.metalinnovations.com "Cuius testiculos habes, habeas cardia et cerebellum." - When you have their full attention in your grip, their hearts and minds will follow. |
On Wed, 25 May 2005 14:00:21 -0500, guynoir
wrote: The side facing the pilot is the face. The side away from the pilot is the back, unless you fly a pusher. That terminology is as intuitively backwards as some of the computer stuff I work with. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Ron Natalie wrote in om: guynoir wrote: The curved side of the blade is called the "back" or "cambered side". The flat side is called the "face" or "thrust side". The back usually doesn't get many nicks in it. I get more dings in the back (the side facing the pilot) than I ever get in the front. |
Roger wrote: On Wed, 25 May 2005 14:00:21 -0500, guynoir wrote: The side facing the pilot is the face. The side away from the pilot is the back, unless you fly a pusher. That terminology is as intuitively backwards as some of the computer stuff I work with. Just think of it as 'little endian' vs. 'big endian'. *GRIN* It makes sense, if you think of it in terms of which 'side' of the prop is doing the work. It's the one to the rear that actually pushes the air around. |
Roger wrote: On Tue, 07 Jun 2005 12:44:23 -0000, (Robert Bonomi) wrote: In article , Roger wrote: On Wed, 25 May 2005 14:00:21 -0500, guynoir wrote: The side facing the pilot is the face. The side away from the pilot is the back, unless you fly a pusher. That terminology is as intuitively backwards as some of the computer stuff I work with. Just think of it as 'little endian' vs. 'big endian'. *GRIN* It makes sense, if you think of it in terms of which 'side' of the prop is doing the work. It's the one to the rear that actually pushes the air around. But...but... but... I was taught a prop "pulls" the air rather than pushing it. Not my fault if you were lied to. *BIG* grin In the standard configuration, the prop "pulls" the airplaine through the air, yes. Absent a "sky hook" to anchor to, it has to push against 'something else' to accomplish that pulling. Lastly, there are two things one must know, to be an "injuneer" -- First: "F equals M A" Second: "You can't push on a rope." Air is _not_ a rope. you *can* push it. snicker |
Filing or dressing out prop nicks is a job for a licensed
mechanic, since there are legal specs that must be adhered to, and the prop manufacturer has more dimensional limits that need to be checked. They learned these things the hard way; don't you go doing the same. The right sort of nick, in the right place, given enough time in operation, will result in a crack that could see a chunk of prop disappear, and the imbalance could tear the engine off the airplane. The airplane will not glide with its engine missing, so nicks need to be taken seriously. I've seen some badly repaired nicks that actually make the prop more likely to fail. Dan |
Do NOT try to dress out the prop yourself. Even a small nick can cause a
prop to fail in flight. If this happens at full power, the engine can be ripped off the airplane in less than a second! Without the engine, the airplane becomes extremely tail heavy and a violent crash is unavoidable. Certain types of nicks on certain models or propellor are fixable. A licensed mechanic with a powerplant rating knows how to properly dress a prop if it's possible, and rebalance and repaint the prop. Don't try to paint the prop yourself. Even a small amount of paint on one side can seriously unbalance a prop. Some propellors are balanced by simply applying varnish to one side...that's all it takes! Get a prop shop or a powerplant mechanic to work on it. wrote: Filing or dressing out prop nicks is a job for a licensed mechanic, since there are legal specs that must be adhered to, and the prop manufacturer has more dimensional limits that need to be checked. They learned these things the hard way; don't you go doing the same. The right sort of nick, in the right place, given enough time in operation, will result in a crack that could see a chunk of prop disappear, and the imbalance could tear the engine off the airplane. The airplane will not glide with its engine missing, so nicks need to be taken seriously. I've seen some badly repaired nicks that actually make the prop more likely to fail. Dan |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
my ignorance | LCT Paintball | Home Built | 25 | April 9th 05 06:54 PM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
