C172 crash at Coney Island
Old May 27th 05, 01:24 PM
Gary Drescher
The preliminary NTSB report is online now.
http://www.ntsb.gov/NTSB/brief.asp?e...26X00678&key=1
There appears to be no indication of engine failure, fuel exhaustion, fire,
or control malfunction. The fuel controls (throttle idle and bent; mixture
rich; both tanks selected) are consistent with spin recovery procedures.
Weather was benign. The weights of the persons on board are not mentioned.
--Gary
  #92
Old May 27th 05, 02:50 PM
Steve S
But 30 degree flap deployment is not what I would use for spin recovery.
Sounds more like a spin following an approach to landing.
Note that the report states that "the crankshaft flange that the propeller
assembly was attached to, was separated from the engine"
Perhaps the engine was running but not turning the prop.
"Gary Drescher" wrote in message
fire, or control malfunction. The fuel controls (throttle idle and bent;
mixture rich; both tanks selected) are consistent with spin recovery
procedures. Weather was benign. The weights of the persons on board are
not mentioned.
--Gary
  #93
Old May 27th 05, 10:52 PM
Ben Hallert
....or that could be impact damage. 500 feet seems low, but that's what
the corridor allows. 30 degrees of flaps... I speculate that slow
flight was being demonstrated. For some reason, the plane slowed past
the stall point at an angle and entered a spin, then had insufficient
altitude to recover.
I'm no expert, but it seems like one plausible scenario that could fit
the evidence.
I wonder if... what if he was working to avoid busting into Class
Bravo, and the maneuvering to do so resulted in an inadvertent loss of
lift?
  #94
Old May 27th 05, 10:57 PM
Gary Drescher
"Ben Hallert" wrote in message
lift?
He was apparently circling at 500', but the Class B at Coney Island begins
at 1500'.
--Gary
  #95
Old May 28th 05, 12:31 AM
RjL
Sorry - Sounds to me like C172 with 4 adults + full fuel in slow flight with
too much bank angle = aggravated stall....
RjL
lift?
at 1500'.
--Gary
  #96
Old May 28th 05, 06:09 AM
Happy Dog
Maybe not slow flight. An instructor would, probably, not do this on a
sightseeing tour and without sufficient recovery altitude. But, speculation
on that aside, I often use a notch or two of flaps when doing a sightseeing
tour. Gives a bit more nose down attitude. Maybe it was that.
moo
  #97
Old May 28th 05, 01:03 PM
Blueskies
"Happy Dog" wrote in message ...
Maybe not slow flight. An instructor would, probably, not do this on a sightseeing tour and without sufficient
recovery altitude. But, speculation on that aside, I often use a notch or two of flaps when doing a sightseeing tour.
moo
Yup 10° flaps for that sort of flying...
C172 Plane crash Orlando, FL CFLav8r Piloting 25 January 15th 05 08:54 PM
Long Island Crash - Kite String? Neb Okla Rotorcraft 5 September 3rd 04 05:43 PM
Navy releases names of 4 killed in island crash Otis Willie Military Aviation 0 August 14th 04 11:21 PM
Madeline Island and Richard I. Bong Museum PIREP Jay Honeck Piloting 3 July 20th 04 03:21 AM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 03:09 AM
