I'm going to disagree with Denny and say it's not nearly that bad. The
engine is certified if it has the appropriate data plate (seemingly without regard to what is attached to the data plate G). However, if indeed there are NO logs, then at this precise moment the engine (and hence the aircraft) are not airworthy. Basically all you are going to need to make it airworthy is a sheet of paper from the AI that did the last annual, with the annual engine signoff. That done, and without evidence of anything to the contrary, you are legal to fly. [And don't say that because there is no log book that you don't know if anything was done since annual to make it unairworthy. Those are independent events, and the logbook is only one slight way you might discover such a change.] Now... the money items: Without proper logbook documentation, it is harder to sell the plane. Not a big problem if you plan to keep the plane a long time (by which time you will have probably gone through an overhaul anyway), but still an issue. Second, you have no record of exactly what is installed in the engine. The last annual AI will be attesting to all the AD's performed as of that time, but you have no formal record that they were properly carried out. Future AI *could* (and very likely might) insist that some work be done to verify the AD's before signing off on the next annual. And you might find yourself doing extensive work (splitting the case) just to find that your engine didn't even fall under some AD in the future. Can you make a NEW logbook? Sure, done all the time. You start by trying to get copies of the last overhaul records, plus whatever the manufacturer might still have on that specific serial number. Ditto the accessories. Then take all the receipts, invoices, etc. And you make up what you can. Perfectly legal... but doesn't really solve all the problems above. Me? I would start with the negotiating position that the engine is due for overhaul and reduce the price as if the engine was at TBO. |
Missing engine | Marty Schmidt | Piloting | 3 | October 27th 04 09:03 PM |
Engines and Reliability | Dylan Smith | Piloting | 13 | June 30th 04 03:27 PM |
My Engine Fire!! | [email protected] | Piloting | 21 | April 2nd 04 05:02 PM |
Engine... Overhaul? / Replace? advice please | text news | Owning | 11 | February 17th 04 04:44 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
