The turn coordinator is almost always a self contained electric unit.
The attitude indicator and DG are unsually powered by air produced by an external "fan" (we call it a pump). It may blow or suck depending on the plane but it makes no difference, the effect is air moving across the instrument. -Robert, CFI |
Robert M. Gary wrote:
The turn coordinator is almost always a self contained electric unit. The attitude indicator and DG are unsually powered by air produced by an external "fan" (we call it a pump). It may blow or suck depending on the plane but it makes no difference, the effect is air moving across the instrument. The advantage a turn coordinator has is that the gyro within doesn't need to be free in space. It's axis barely changes, which means it's much easier to direct drive with an electric motor. It only needs to register a slight precession force. |
![]() "Ron Natalie" wrote The advantage a turn coordinator has is that the gyro within doesn't need to be free in space. It's axis barely changes, which means it's much easier to direct drive with an electric motor. It only needs to register a slight precession force. Interesting. I didn't realize that was the reason. I still have to ask. Why are the damn things so much more expensive than their vacuum powered brethren? An electric motor just should not cost that much more! -- Jim in NC |
Morgans wrote:
"Ron Natalie" wrote The advantage a turn coordinator has is that the gyro within doesn't need to be free in space. It's axis barely changes, which means it's much easier to direct drive with an electric motor. It only needs to register a slight precession force. Interesting. I didn't realize that was the reason. I still have to ask. Why are the damn things so much more expensive than their vacuum powered brethren? An electric motor just should not cost that much more! It's not a plain brushed electric motor - the brushes won't stand for long in a gyro and you do not want the brush dust inside the gyro. The traditional way is to use a variable reluctance AC motor and an inverter to drive it. I've been told that there are also brushless DC motors in the later models. -- Tauno Voipio tauno voipio (at) iki fi |
"Proceed on Course" = "Right turn approved"? | Bob Chilcoat | Piloting | 41 | July 18th 04 11:48 PM |
Piper Arrow electric fuel-pump | MC | General Aviation | 7 | June 3rd 04 02:50 AM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
FA: Electric Turn and Bank 2-1/4" | KC | Aviation Marketplace | 2 | December 29th 03 05:32 PM |
Rate of turn indicator on commercial jets (Boeing / Airbus) | Mark | Simulators | 1 | November 1st 03 10:35 AM |
