Below sea level
Old June 13th 05, 09:09 AM
Hilton
Default Below sea level
Hi,
How is standard temperature and pressure defined below sea level? How does
DA increase/decrease below sea level? I know that the gravitation force
starts decreasing in a *linear* fashion below sea level, but how that affect
the temp, pressure, and DA is beyond me. Any books, or URLs that could help
me out here?
Thanks!
Hilton
Old June 13th 05, 09:27 AM
Peter Duniho
"Hilton" wrote in message
ink.net...
Same as above sea level. Take the standards at sea level, apply a standard
adjustment, viola.
How does DA increase/decrease below sea level?
Same as above sea level, except in the opposite direction. Below sea level,
pressure altitude decreases, which decreases density altitude. Of course,
temperature has the same effect regardless of altitude; high temperature
increases density altitude, low temperature decreases density altitude.
As far as I know, the difference in gravity has to do with the amount of
mass under you, and is negligible with respect to temperature or pressure.
Same thing would be true of high-elevation terrain.
but how that affect the temp, pressure, and DA is beyond me.
I do not believe that the change in gravitation force is significant for the
purposes of piloting an aircraft.
Basically, nothing unusual happens just because you went below sea level.
"Mean sea level" is simply a convenient reference point. Just as you could
set your reference point to what we now call 4000' MSL, and then find that
density altitude simply decreases below that according to pressure altitude,
and temperature increases or decreases density altitude in the same way it
does at any altitude...the exact same thing happens below sea level.
I haven't seen any calls to adjust density altitude to account for higher
gravitational forces at higher altitudes, nor would I expect to see any call
to do so at extremely low altitudes. Note that we also don't compensate in
our calculations for changes in gravity due to changes in our flight
altitude above ground level.
As far as us pilots are concerned, gravity is exactly the same everywhere.
Pete
Old June 13th 05, 12:41 PM
Dylan Smith
ink.net...
adjustment, viola.
On a point of pedantry, what does a stringed musical instrument, a
little larger than a violin, have to do with the subject at hand? :-)
Especially since airports below MSL aren't that far below MSL anyway
(IIRC, the 'deepest' airport in the continental US is only about -200 MSL,
but the highest, Leadville, has an additional 9000 ft of rock below it).
I've been to a below MSL airport - Thermal (Palm Springs), California.
I didn't notice any difference. But it was kind of neat watching a
correctly set altimeter go below 0 feet :-)
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Old June 13th 05, 04:38 PM
RST Engineering
Furnace Creek, minus 210.
Old June 13th 05, 08:45 PM
John Galban
adjustment, viola.
Darn! You beat me to it :-)
Actually, it's an American custom that you might not have picked up
in your time here. We usually have our Koch chart taped to the back of
our violas (the instrument, not the flower).
Old June 13th 05, 10:34 AM
Cub Driver
Seems to me that the places where you could fly below MSL are very
hot. Wouldn't that affect the aircraft more than the altitude, which
in any event would not be very many feet below 0 MSL?
-- all the best, Dan Ford
email (put Cubdriver in subject line)
Warbird's Forum:
www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
In Search of Lost Time: www.readingproust.com
Old June 13th 05, 02:21 PM
Actualy, the places I know of are not very hot but rather cool and
humid.
I'm serious here, it is a small country called The Netherlands which is
for about one third below actual seal level.
-Kees
Old June 14th 05, 01:52 PM
It is not that bad, lowest point here is -22,18 ft.
But what makes some people nervous overhere is that the sea is just a
few hunderd ft away.
-Kees
Old June 13th 05, 03:05 PM
Larry Dighera
On Mon, 13 Jun 2005 05:34:13 -0400, Cub Driver
wrote in
Bad Water, the lowest point in the western hemisphere, located in the
Death Valley is 282' below sea level.
http://www.virtualtourist.com/travel...ater-BR-1.html
The lowest place in the world is the Dead Sea at 1,395' below sea
level: http://www.extremescience.com/DeadSea.htm
Displaced AFSS "controllers" heading for BIL and GRB Chip Jones Instrument Flight Rules 12 April 10th 05 09:22 PM
Outside loops in a Decathlon [email protected] Aerobatics 12 March 8th 05 07:14 PM
PIREP--CO Experts low level carbon monoxide detector Jay Honeck Piloting 10 December 3rd 04 11:21 AM
Altimeter setting != Sea Level Pressure - Why? JT Wright Piloting 5 April 5th 04 01:04 AM
