"Hilton" wrote in message
ink.net... How is standard temperature and pressure defined below sea level? Same as above sea level. Take the standards at sea level, apply a standard adjustment, viola. How does DA increase/decrease below sea level? Same as above sea level, except in the opposite direction. Below sea level, pressure altitude decreases, which decreases density altitude. Of course, temperature has the same effect regardless of altitude; high temperature increases density altitude, low temperature decreases density altitude. I know that the gravitation force starts decreasing in a *linear* fashion below sea level As far as I know, the difference in gravity has to do with the amount of mass under you, and is negligible with respect to temperature or pressure. Same thing would be true of high-elevation terrain. but how that affect the temp, pressure, and DA is beyond me. I do not believe that the change in gravitation force is significant for the purposes of piloting an aircraft. Basically, nothing unusual happens just because you went below sea level. "Mean sea level" is simply a convenient reference point. Just as you could set your reference point to what we now call 4000' MSL, and then find that density altitude simply decreases below that according to pressure altitude, and temperature increases or decreases density altitude in the same way it does at any altitude...the exact same thing happens below sea level. I haven't seen any calls to adjust density altitude to account for higher gravitational forces at higher altitudes, nor would I expect to see any call to do so at extremely low altitudes. Note that we also don't compensate in our calculations for changes in gravity due to changes in our flight altitude above ground level. As far as us pilots are concerned, gravity is exactly the same everywhere. Pete |
On 2005-06-13, Peter Duniho wrote:
"Hilton" wrote in message ink.net... How is standard temperature and pressure defined below sea level? Same as above sea level. Take the standards at sea level, apply a standard adjustment, viola. On a point of pedantry, what does a stringed musical instrument, a little larger than a violin, have to do with the subject at hand? :-) I know that the gravitation force starts decreasing in a *linear* fashion below sea level As far as I know, the difference in gravity has to do with the amount of mass under you, and is negligible with respect to temperature or pressure. Same thing would be true of high-elevation terrain. Especially since airports below MSL aren't that far below MSL anyway (IIRC, the 'deepest' airport in the continental US is only about -200 MSL, but the highest, Leadville, has an additional 9000 ft of rock below it). I've been to a below MSL airport - Thermal (Palm Springs), California. I didn't notice any difference. But it was kind of neat watching a correctly set altimeter go below 0 feet :-) -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Furnace Creek, minus 210.
Jim (IIRC, the 'deepest' airport in the continental US is only about -200 MSL, but the highest, Leadville, has an additional 9000 ft of rock below it). |
![]() Dylan Smith wrote: On 2005-06-13, Peter Duniho wrote: Same as above sea level. Take the standards at sea level, apply a standard adjustment, viola. On a point of pedantry, what does a stringed musical instrument, a little larger than a violin, have to do with the subject at hand? :-) Darn! You beat me to it :-) Actually, it's an American custom that you might not have picked up in your time here. We usually have our Koch chart taped to the back of our violas (the instrument, not the flower). John Galban=====N4BQ (PA28-180) |
Displaced AFSS "controllers" heading for BIL and GRB | Chip Jones | Instrument Flight Rules | 12 | April 10th 05 09:22 PM |
Outside loops in a Decathlon | [email protected] | Aerobatics | 12 | March 8th 05 07:14 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
PIREP--CO Experts low level carbon monoxide detector | Jay Honeck | Piloting | 10 | December 3rd 04 11:21 AM |
Altimeter setting != Sea Level Pressure - Why? | JT Wright | Piloting | 5 | April 5th 04 01:04 AM |
