Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
Towplane strut problem
Old June 15th 05, 07:25 PM
Denny
I learned to fly in a J-3 and I have owned various steel tube airplanes
over the years... I have helped to jig, drill, and ream the fuselage
tabs and mount biplane wings... I doubt that there is any wear allowed
by Piper at that lower spar attach tab... The hole in the fuselage tab
should be a close tolerance fit for the bolt... I always considered
the wing tip shake test to require no relative movement of the wing in
relation to the strut/fuselage - other than the usual
springing/bouncing of the entire airframe with a vigorous shake...
With any slop in the strut flutter becomes an issue... I urge that you
folks get an experienced steel tube airframe mechanic to make the
repair soon...
denny
Heater problem fixed! Jim Burns Owning 14 December 17th 04 10:38 PM
SSA Website problem Raphael Warshaw Soaring 2 February 12th 04 02:56 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 09:10 PM
Help with serious Glider Registration Problem Soaring 5 November 12th 03 04:01 PM
Problem: Ground Speed Estimate with Volkslogger and WinPilot RamyYanetz Soaring 3 August 26th 03 03:06 PM
