Transponder issue
Old June 22nd 05, 01:03 AM
Mike Rapoport
Four screws, one static line and a single connector. Do it yourself.
Mike
MU-2
"Jimmy B." wrote in message
ink.net...
Thanks to all who mentioned the encoder. Do any of you remember how much
it cost to have the encoder replaced?
Doug Vetter wrote:
Jimmy B. wrote:
I have a King KT76 transponder that has picked up a little problem. It
takes about 10 minutes before it starts transmitting the mode C
information. ATC is getting the transmission alright, there is just no
altitude information.
snip
I agree with everyone else. It's the encoder. Had the same thing happen
a year a couple years back.
I'll add the following recommendations:
1) buy a new encoder -- don't try to repair the existing one. It rarely
makes financial sense. The ACK is the least expensive. The Sandia the
most expensive. They differ in maximum approved altitude, number / type
of outputs (serial vs. gray code), and features (the Sandia has an
altitude monitor and 10' resolution).
2) if you have any plans to upgrade to a GPS or transponder that can
utilize it, buy an encoder that provides 10' resolution. They're a bit
more expensive, but they're worth it, IMHO.
-Doug
Doug Vetter, CFIMEIA
http://www.dvcfi.com
Operation without a transponder flyer Piloting 11 September 14th 04 08:48 AM
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
Transponder petition Ian Cant Soaring 11 February 28th 04 06:38 AM
More on transponder petition Ian Cant Soaring 1 February 27th 04 06:37 PM
