Leaning Procedure for a Carbureted 182
Old June 25th 05, 11:57 PM
Scott Skylane
RST Engineering wrote:
Then you will have plug fouling issues with the O-470 for the rest of your
airplane's life.
Bulls**t. I've put almost 500 exclusively 100LL hours on my O-470R with
nary a single plug fouled.
Happy Flying!
Scott Skylane
N92054
Old June 26th 05, 12:43 AM
Jeffrey
What's your technique Scott?
"Scott Skylane" wrote in message
your airplane's life.
Happy Flying!
Scott Skylane
N92054
Old June 26th 05, 08:07 AM
tony roberts
Leeeaaaaannnn - on the ground until it almost quits,
and in the air - be aggressive - a cht/egt monitor helps! I recommend
ECI.
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Happy Flying!
Scott Skylane
N92054
Old June 26th 05, 08:52 AM
Scott Skylane
Well it's a very detailed, scientifically validated protocol, and I'll
attempt to outline the specifics he
For ground operation, I'll pull the mixture out, oh, about an inch and a
half or so, give or take.
Full rich for takeoff and climb, up to about 5000 ft or so (home base is
at sea level). Lean it a little for climbs above 5000 ft.
For cruise, pull the mixture out, oh, about an inch and a half or so,
give or take depending on altitude (pull out more at higher alt).
I have no engine monitor, so I used to pull the mix untill power loss,
then enrich slightly for cruise, but it always ended up in the same
place, so see above.
Thats it, as far as leaning goes. I cruise at 23 square, get about 150
mph on 12 gph.
I try to keep manifold pressure as high as possible. After takeoff, I
leave the throttle full, and pull back RPM to 2450. For power reduction
approaching the traffic pattern, I pull the RPM's down with the MP, down
to 2000 RPM and about 18" for pattern entry. My theory is, higher
combustion chamber pressures should help scavenge the lead better. This
theory is based on nothing but my gut.
Happy Flying!
Scott Skylane
N92054
Old June 28th 05, 02:17 AM
tony roberts
Hi Scott
Are you at Arlington this year?
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Happy Flying!
Scott Skylane
N92054
Old June 26th 05, 08:19 AM
Dale
airplane's life.
Same here....around 800 hours and no fouling problems.
Usually leaned on the ground. Leaned at cruise regardless of altitude.
Had an EI engine scanner/monitor with 6 leads EGT/CHT.
Dale L. Falk
Leaning for taxi Jim Rosinski Piloting 28 September 12th 04 03:53 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
Unusual Procedure at DFW Toks Desalu Piloting 9 December 17th 03 05:27 PM
O-320 leaning Roger Long Piloting 5 November 8th 03 11:40 PM
