#41
Juan,
Running rich of peak aviods the peak settings that can overheat things and do damage. Not at all true. In fact, completely false. Sorry. Come on, Thomas. What in the world makes you think that the effects of heat due to leaning to peak EGT at high power settings are NOT going to create problems for the engine? This is common knowledge -- the closer your EGT gets to 1600 degF for extended periods, the higher the chances your engine will not reach or exceed TBO. The absolute worst place to run your engine with regard to extreme numbers (temperatures AND pressures) is the 50 degree rich of peak area. That is in direct contradiction to your statement above. And that's what my comment referred to. The key temp to manage is cylinder head temp, not EGT. Running at peak EGT at high power settings for extended periods -will- have a negative effect on your engine. That's why none of the manufacturers recommend doing this. Define "high". The manufacturer's absolutely do recomment running at peak EGT at their recommended cruise power setting. They call that the "best economy" setting. -- Thomas Borchert (EDDH) |
#42
Juan,
Running lean of peak also results in reduced performance, rough engine operation in many cases and shortened TBO due to the above-mentioned oxidative attack of exhaust and combustion chamber components. Running lean of peak also has another side effect, increase in oil acidity, which causes oxidation in engine internal components (same thing happens if you don't operate the engine often enough to burn off any condensation in the oil). Care to back these statements up with numbers? -- Thomas Borchert (EDDH) |
#43
Juan,
You DO have to be concerned about running too lean, which is why Continental does not recommend leaning for extended periods of time at high power settings (above 65%). Ok, I'll try again. The point is to run at the right mixture setting. That might be very rich of peak or lean of peak. Whichever you chose, "too lean" is not the answer to "what's dangerous?". -- Thomas Borchert (EDDH) |
#44
![]() "Thomas Borchert" wrote in message ... Juan, Running rich of peak aviods the peak settings that can overheat things and do damage. Not at all true. In fact, completely false. Sorry. Come on, Thomas. What in the world makes you think that the effects of heat due to leaning to peak EGT at high power settings are NOT going to create problems for the engine? This is common knowledge -- the closer your EGT gets to 1600 degF for extended periods, the higher the chances your engine will not reach or exceed TBO. The absolute worst place to run your engine with regard to extreme numbers (temperatures AND pressures) is the 50 degree rich of peak area. I never said the engine should be run 50 degrees rich of peak. You're the one that's saying something totally different, that running lean of peak is good for the engine, which it is not. Running at peak EGT at high power settings for extended periods -will- have a negative effect on your engine. That's why none of the manufacturers recommend doing this. Define "high". The manufacturer's absolutely do recomment running at peak EGT at their recommended cruise power setting. They call that the "best economy" setting. No, they do not. And if you want to play Clinton games, define "absolutely." And RTFM the manual for the engine. |
#45
![]() "Thomas Borchert" wrote in message ... Juan, Running lean of peak also results in reduced performance, rough engine operation in many cases and shortened TBO due to the above-mentioned oxidative attack of exhaust and combustion chamber components. Running lean of peak also has another side effect, increase in oil acidity, which causes oxidation in engine internal components (same thing happens if you don't operate the engine often enough to burn off any condensation in the oil). Care to back these statements up with numbers? Don't need to, Kas Thomas and the manufacturers and engineers who analyze this sort of thing already did. You got any evidence to the contrary other than digital saliva, go ahead and show it. Get yourself a copy of 101+ Ways to Extend The Life Of Your Engine and educate yourself, Thomas. |
#46
![]() "Thomas Borchert" wrote in message ... Juan, You DO have to be concerned about running too lean, which is why Continental does not recommend leaning for extended periods of time at high power settings (above 65%). Ok, I'll try again. The point is to run at the right mixture setting. That might be very rich of peak or lean of peak. Whichever you chose, "too lean" is not the answer to "what's dangerous?". The context is a carbureted 182, an O-470. For the specific model mentioned in this thread, neither the manufacturer nor TBO Advisor recommends running lean of peak, period, or at peak EGT at power settings over 65%. |
#47
Juan,
You got any evidence to the contrary other than digital saliva, go ahead and show it. http://www.gami.com/frames.htm Your god is Kas Thomas. Mine isn't ;-) -- Thomas Borchert (EDDH) |
#48
![]() "Thomas Borchert" wrote in message ... Juan, You got any evidence to the contrary other than digital saliva, go ahead and show it. http://www.gami.com/frames.htm Your god is Kas Thomas. Mine isn't ;-) Then talk to your priest and switch bibles, kiddo, because the data on this web does not support your assertions. It's not even close. Heck, you didn't even bother to check to see if the engine that is the subject of this thread is on the approved list for the GAMI products! Sorry to shoot you down like that, but that's what happens when you don't do your homework. Juan |
#49
Juan,
Then talk to your priest and switch bibles, kiddo, "Kiddo", huh? So now all you have left is to become condescending? Usenet is just so much fun. because the data on this web does not support your assertions. It's not even close. Guess you need reading lessons, kiddo (see, I can do it, too). Heck, you didn't even bother to check to see if the engine that is the subject of this thread is on the approved list for the GAMI products! The subject of the thread went from a specific engine to general leaning procedures real quick (read it). I NEVEr claimed that GAMIjectors were for O-470s. The general principles still hold. And your claim of "richer is cooler" is still not true. Sorry to shoot you down like that, Excuse me? -- Thomas Borchert (EDDH) |
#50
![]() "Thomas Borchert" wrote in message ... because the data on this web does not support your assertions. It's not even close. Guess you need reading lessons, kiddo (see, I can do it, too). But you can't back it up with facts, kiddo. I can. ![]() Heck, you didn't even bother to check to see if the engine that is the subject of this thread is on the approved list for the GAMI products! The subject of the thread went from a specific engine to general leaning procedures real quick (read it). I NEVEr claimed that GAMIjectors were for O-470s. The general principles still hold. And your claim of "richer is cooler" is still not true. The subject of this thread never left the issue of leaning carbureted engines before you started talking about LOP leaning. LOP is only for some fuel injected engines, and only those with very exact fuel metering and the right hardware to monitor what's going on in each cylinder. And now you're saying I'm claiming richer is cooler? chuckle I had no idea you liked musical chairs so much. I guess the shoe does fit. Sorry to shoot you down like that, Excuse me? Pick up your parachute before you leave the room. I made my point, I'm outta here. :P Juan |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Leaning for taxi | Jim Rosinski | Piloting | 28 | September 12th 04 03:53 AM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
Unusual Procedure at DFW | Toks Desalu | Piloting | 9 | December 17th 03 05:27 PM |
O-320 leaning | Roger Long | Piloting | 5 | November 8th 03 11:40 PM |
