"Mike Beede" wrote in message
... The only time it really makes a difference is if you accidentally switch it to the 7500+ neighborhood. A good rule of thumb is to roll in the first number (which at least in the Minneapolis area is never 7) and then do the rest. Do people get 7xxx codes elsewhere in the United States? Not sure about assigning 7xxx codes... I found a list of transponder codes besides the 1200/7500/7600/7700: 1255 is for VFR aircraft engaged in fighting forest fires 1277 is for VFR aircraft engaged in search & rescue operations 4000 is reserved for VFR military aircraft on training missions 4400-4477 are reserved for aircraft operating above FL600 At no time should 7777 be used, as this is for military interception procedures (Source: 2003-2004 Iowa Airport Directory page 135) Are there others? |
Would be kind of cute to "accidentally" select 44xx and
see what altitude they assign... "Sven" wrote in message news:Ewqgb.701786$uu5.115368@sccrnsc04... "Mike Beede" wrote in message ... The only time it really makes a difference is if you accidentally switch it to the 7500+ neighborhood. A good rule of thumb is to roll in the first number (which at least in the Minneapolis area is never 7) and then do the rest. Do people get 7xxx codes elsewhere in the United States? Not sure about assigning 7xxx codes... I found a list of transponder codes besides the 1200/7500/7600/7700: 1255 is for VFR aircraft engaged in fighting forest fires 1277 is for VFR aircraft engaged in search & rescue operations 4000 is reserved for VFR military aircraft on training missions 4400-4477 are reserved for aircraft operating above FL600 At no time should 7777 be used, as this is for military interception procedures (Source: 2003-2004 Iowa Airport Directory page 135) Are there others? |
"John Harper" wrote in message
news:1065499936.802114@sj-nntpcache-3... Would be kind of cute to "accidentally" select 44xx and see what altitude they assign... I doubt that they would confuse someone flying at FL065 with someone at FL650. The saying you won't hear: "Cessna Skyhawk, climb to FL650, Squawk 4444..." |
"Sven" writes:
I found a list of transponder codes besides the 1200/7500/7600/7700: 1255 is for VFR aircraft engaged in fighting forest fires 1277 is for VFR aircraft engaged in search & rescue operations 4000 is reserved for VFR military aircraft on training missions 4400-4477 are reserved for aircraft operating above FL600 At no time should 7777 be used, as this is for military interception procedures (Source: 2003-2004 Iowa Airport Directory page 135) Are there others? Here are some Canadian default codes (uncontrolled, or no transponder code yet assigned): 1400 VFR above 12,500 ft 1000 IFR in low-level airspace 2000 IFR in high-level airspace All the best, David |
And there are other codes that cause alarms that are secret, so don't
worry about it and just switch the numbers. Sven wrote: "Mike Beede" wrote in message ... The only time it really makes a difference is if you accidentally switch it to the 7500+ neighborhood. A good rule of thumb is to roll in the first number (which at least in the Minneapolis area is never 7) and then do the rest. Do people get 7xxx codes elsewhere in the United States? Not sure about assigning 7xxx codes... I found a list of transponder codes besides the 1200/7500/7600/7700: 1255 is for VFR aircraft engaged in fighting forest fires 1277 is for VFR aircraft engaged in search & rescue operations 4000 is reserved for VFR military aircraft on training missions 4400-4477 are reserved for aircraft operating above FL600 At no time should 7777 be used, as this is for military interception procedures (Source: 2003-2004 Iowa Airport Directory page 135) Are there others? |
![]() "Newps" wrote in message news:3Gzgb.514047$Oz4.370169@rwcrnsc54... And there are other codes that cause alarms that are secret, so don't worry about it and just switch the numbers. Awww Newps, now we have to kill you... Chip, ZTL |
("Chip Jones" wrote)
And there are other codes that cause alarms that are secret, so don't worry about it and just switch the numbers. Awww Newps, now we have to kill you... Newps, quick, hide in the FAR's!!! Just saw this play (again) this past week. One of my favorites. From A Man for All Seasons, by Robert Bolt Setting - Sir Thomas More has declined to employ Richard Rich, who has just left the room. Wife: Arrest him! Mo For what? Wife: He's dangerous! Roper: For all we know he's a spy! Daughter: Father, that man's bad! Mo There's no law against that! Roper: There is, God's law! Mo Then let God arrest him! Wife: While you talk he's gone! Mo And go he should, if he were the Devil himself, until he broke the law! Roper: So, now you give the Devil the benefit of law! Mo Yes! What would you do? Cut a great road through the law to get after the Devil? Roper: Yes, I'd cut down every law in England to do that! Mo Oh? And when the last law was down, and the Devil turned 'round on you, where would you hide, Roper, the laws all being flat? This country is planted thick with laws, from coast to coast, Man's laws, not God's! And if you cut them down (and you're just the man to do it!), do you really think you could stand upright in the winds that would blow then? Yes, I'd give the Devil benefit of law, for my own safety's sake! -- Montblack |
![]() "Montblack" wrote in message ... ("Chip Jones" wrote) And there are other codes that cause alarms that are secret, so don't worry about it and just switch the numbers. Awww Newps, now we have to kill you... Newps, quick, hide in the FAR's!!! Just saw this play (again) this past week. One of my favorites. From A Man for All Seasons, by Robert Bolt Setting - Sir Thomas More has declined to employ Richard Rich, who has just left the room. Wife: Arrest him! Mo For what? Wife: He's dangerous! Roper: For all we know he's a spy! Daughter: Father, that man's bad! Mo There's no law against that! Roper: There is, God's law! Mo Then let God arrest him! Wife: While you talk he's gone! Mo And go he should, if he were the Devil himself, until he broke the law! Roper: So, now you give the Devil the benefit of law! Mo Yes! What would you do? Cut a great road through the law to get after the Devil? Roper: Yes, I'd cut down every law in England to do that! Mo Oh? And when the last law was down, and the Devil turned 'round on you, where would you hide, Roper, the laws all being flat? This country is planted thick with laws, from coast to coast, Man's laws, not God's! And if you cut them down (and you're just the man to do it!), do you really think you could stand upright in the winds that would blow then? Yes, I'd give the Devil benefit of law, for my own safety's sake! You definitely need less caffeine. :~) |
VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 04:29 PM |
FS: Narco AT-50A Transponder with ACK Encoder | JR | Home Built | 0 | April 29th 04 11:33 AM |
Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 12:18 AM |
For Jim Weir: Transponder Installation | Ron Wanttaja | Home Built | 11 | February 3rd 04 03:26 PM |
transponder check? | Russell Duffy | Home Built | 10 | August 14th 03 11:36 PM |
