Alu corrosion protection
Old July 7th 05, 04:44 PM
Udo Rumpf
In that case I will restate my inquiry.
I am aware of the conventional corrosion protection regarding alu.
The top surfaces have been look after.
I am looking for a product that will protect the "bottom" of an alu
trailer.
It should be able to seep into, as well as creep in-between pieces of
alu that have been riveted. (HL) I will not take the trailer apart to get
at
the crevices. Either spray or brush on will be a good solution
The trailer is built and conventional alu protection on bottom of the
trailer can not be used.
I hope this is more precise
Regards
Udo
"HL Falbaum" wrote in message
Actually, the poster covers the question--stating there is no "shortcut"
to stabilizing the corrosion. It "hides" in crevices and comes out later.
The "glider deserves it" refers to the protection an intact trailer bottom
affords a glider.
Hartley Falbaum
"Udo Rumpf" wrote in message
At last some one read the post.
In an attempt to be helpful one keys in on a few words.
Udo
I believe the original post was about the bottom of the trailer instead
of the glider.
Larry
" wrote in message
I would only add two things to the above response. I would use an
etching solution such as Alumiprep 33 or Turco with the ScotchBrite,
rinse, then coat with Alodine, rinse and prime with a Zinc Chromate
paint before topcoating with a two part polyurethane. It's a lot of
work but your glider deserves it.
As for the shortcut solution, there are coatings which would protect
the surface but (at least for aluminium) I haven't seen anything that
would stabilize the corrosion that is already there.
Old July 7th 05, 10:37 PM
trailer.
at
Regards
Udo
WD-40 was created for pretty much this type of thing. It obviously
won't repair corrosion,but likely will slow it down. It does wick into
crevices.
UH
affords a glider.
Hartley Falbaum
Udo
of the glider.
Larry
" wrote in message
Surface Corrosion? Joaquin Murrieta Home Built 2 May 3rd 05 01:19 AM
Corrosion Protection jc Home Built 1 February 15th 05 11:42 AM
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
Corrosion Protection on Alluminum Sheet Aircraft? DL152279546231 Home Built 6 February 10th 04 05:10 AM
How much corrosion is too much? Carl Orton Owning 5 February 2nd 04 01:31 AM
