Corrosion Protection
Old February 13th 05, 10:49 AM
jc
Default Corrosion Protection
Looking at a LSA (Australian Ultralight) 6061 homebuilt for next to sea
outside storage. I would prefer not to paint it and loose ~ 1hr of fuel so
would a geen/gold chromate colour loose too much in corrosion protection?
Rude comments invited.
regards
jc
LEGAL - I don't believe what I wrote and neither should you. Sobriety and/or
sanity of the author is not guaranteed
EMAIL - and are not valid email
addresses. news2x at perentie is valid for a while.
Old February 15th 05, 11:42 AM
I won't do it - not in a salt environment. Depends on how long you expect it
to last I guess. You might get away with it in the desert but not near the
sea.
I would definitely alodine and prime all parts prior ro assembly. Goop all
the joints on assembly then apply a good quality urethane finish (or
similar). Anything less is not worth the risk in a salt environment. If you
don't believe me talk to operators of GA airplanes that live at airports
near the sea.
"jc" wrote in message
regards
jc
and/or
Soverignty Protection Fighter Charles Talleyrand Military Aviation 11 July 19th 04 11:56 PM
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
Corrosion Protection on Alluminum Sheet Aircraft? DL152279546231 Home Built 6 February 10th 04 05:10 AM
How much corrosion is too much? Carl Orton Owning 5 February 2nd 04 01:31 AM
Corrosion X Applicators Hankal Owning 5 July 7th 03 06:07 PM
