Transponder code switching
Old October 9th 03, 01:35 AM
Newps
Dark lonely night and you are the only airplane in the airspace
squawking VFR. You call up for service I'll give you a code and radar
contact in the same breath.
David Megginson wrote:
Newps writes:
It takes at least two sweeps and sometimes as many as 5 sweeps before
the radar will tag you up on a code you're squawking.
Is that true of all radar equipment? I've sometimes been assigned a
new squawk code then heard "radar contact" within a couple of seconds
(usually, though, it's more like 20-30 seconds, which would agree with
what Newps writes).
All the best,
David
VHF & Transponder antenna Steve Home Built 1 December 6th 04 04:29 PM
FS: Narco AT-50A Transponder with ACK Encoder JR Home Built 0 April 29th 04 11:33 AM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
For Jim Weir: Transponder Installation Ron Wanttaja Home Built 11 February 3rd 04 03:26 PM
transponder check? Russell Duffy Home Built 10 August 14th 03 11:36 PM
