SeeYou Problem?
Old July 22nd 05, 05:27 PM
Paul M. Cordell
Thanks Tom,
I tried your fix in V 3.1. The Phases Tab of the Statistics page is
still blank. I did have the correct times in the Soaring Begin and
End box's.
P. Corbett wrote:
Tom:
BINGO!
I did as you suggested and the flight stats were displayed immediately. I
hope this solution works for the others have the same problem.
Thanks again,
Paul Corbett
ZZ
"5Z" wrote in message
Paul,
Open the flight in SeeYou, then right click to bring up a menu and
select flight properties.
On the flight tab you can select "pure glider". There, you can also
edit soaring begin and end times, which will then be reflected in all
further analysis.
-Tom
Heater problem fixed! Jim Burns Owning 14 December 17th 04 10:38 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 09:10 PM
Help with serious Glider Registration Problem Soaring 5 November 12th 03 04:01 PM
EGT Problem Dennis O'Connor Owning 4 August 27th 03 04:25 PM
Problem: Ground Speed Estimate with Volkslogger and WinPilot RamyYanetz Soaring 3 August 26th 03 03:06 PM
