I have forwarded this thread to the manufacturer of my redrive and to
the rotary engine discussion group to see if this concern has been borne out in that engine type (that is one of the powerplants the OP was inquiring about, as well as the powerplant that I am building now). I am not contesting what you are claiming with regards to GO- series engines, and operation at zero or less than zero net thrust in those powerplants. Dave PittsS1C wrote: I believe the porper operation of geard engines is not operate in regions of zero thrust during glides (which is a common occurnace using beta during taxi...) Mike "Dave S" wrote in message nk.net... Wouldn't you have this "effect" ANY time you went from a thrusting to a braking action with regards to thrust generated? If I pulled power back, set the pitch to flat, and pushed the nose over, wouldn't the prop be "driving" the engine in the manner you describe? All of this is able to be done without a specific Beta range. Dave PittsS1C wrote: Is it a good idea to have beta with any geared engines? Aren't there typically problems with chattering the gears back and forth leading to failures? Mike "Dave S" wrote in message hlink.net... I believe you are mistaken on the IVO. The IVO has a specific range of travel that is accomplished by twisting the blade midshaft, not rotating the entire blade in the hub. Also, with the auto engines the original poster is discussing, it is less a function of the engine and more a function of will the PSRU (re-drive) support a hydraulic governor. The Marcotte and Mistral PSRU's will support a hydraulic constant speed prop, others such as the Real World Solutions brand will not. An electric MT can be obtained that will run in the beta (and even reverse) ranges, but that is a $10k US proposition. Of course, getting a hydraulic governor, the price difference for a redrive that supports one, and getting a hydraulic CS prop, you are likely there with the cost of an Electric MT in the first place. It costs money.. plain and simple. The IVO may be an option for you, but as for a specific "beta" range, I am fairly sure it doesnt have one. Dave Gig 601XL Builder wrote: I believe both the Woodcomp and the IVO will go into Beta. "Rob Fonhof" wrote in message ... Hi All. Just wondering if there are any props out there that can be used on an experimental aircraft engine, ie:subaru or RX-8 Renesis, which have a beta range. Don't even want to consider a certified unit as this would probably cost more than the rest of the firewall forward components. Thanks in advance, Rob. Melbourne Australia. |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
Prop Pitch Question | Eugene Wendland | Home Built | 2 | April 25th 04 03:22 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
