Interesting!
The left CHT gauge on our Aztec started acting the same way. It hangs down around 250 - 300 degrees and just kind of bounces around never indicating a steady temperature. Normally they both run around 380 and the needles are rock solid. Both engines have the standard single probe. Recently, I changed spark plugs on the left engine and noted that we would soon be needing new harnesses. Some of the wires were getting a little frayed near the plug connectors. If one of the wires is shot, could a non firing plug on the cylinder that the probe is installed in also cause the symptoms that I am seeing on our CHT? Run ups are good, no missing or roughness noticed. Jim Burns wrote in message oups.com... I am stumped as to what could be causing thing and am hoping someone here can help me out. A couple of flights ago I noticed that my EGT gauge started fluctuating. Not fast but up and down a couple needle widths every second or two. Then on the next flight I noticed that the tach has started as well. Up and down 25 rpm or so. I just had a cylinder overhauled about a hundred hours ago and I do have have a much larger drop in the right mag that I need to clear to get to normal on each flight. My mechanic looked at my plugs last week and cleaned one he said that had oil on it from the overhauled cylinder. I took it flying today to see if that cleared the problem but it is still there. Any ideas or thoughts? |
Mechanical tach failure? | Rich S. | Home Built | 25 | November 6th 04 03:30 PM |
Tachometer or Tach Cable | Rich | Owning | 14 | October 14th 04 02:54 AM |
Analog tach replacement | Mike Noel | Owning | 12 | July 20th 04 10:20 PM |
Logging Time Consistently - Hobbs AND Tach | Carl Orton | Piloting | 11 | June 29th 04 09:52 PM |
Tach Vs. Hobbs Time | John Roncallo | Owning | 33 | January 7th 04 12:42 AM |
