Cherokee battery box repair
Old August 29th 05, 09:06 PM
nrp
I don't know Cherokee electrics, but does it maybe offer a way to (very
slowly) charge the battery thru the external service plug?
My Cessna 172M has a funny diode-resistor circuit like that in the
battery circuit in which that's the only reason I can see for it. It
is not described in the POH or even the service manual. Otherwise with
a completely dead battery, if I used the ground service plug to start
it, there still wouldn't be anything in the battery to initialize the
alternator.
Flyback diodes don't usually have a resistor in series with them.
Old August 29th 05, 09:48 PM
Another good idea, but the schematic has rather clearly shown the
diode/connector setup for the external connection, but has it shown as "optional."
This diode/resistor is in addition to that.
nrp wrote:
: I don't know Cherokee electrics, but does it maybe offer a way to (very
: slowly) charge the battery thru the external service plug?
: My Cessna 172M has a funny diode-resistor circuit like that in the
: battery circuit in which that's the only reason I can see for it. It
: is not described in the POH or even the service manual. Otherwise with
: a completely dead battery, if I used the ground service plug to start
: it, there still wouldn't be anything in the battery to initialize the
: alternator.
: Flyback diodes don't usually have a resistor in series with them.
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Checking the battery in a Cherokee nobody Owning 15 May 5th 05 12:39 PM
Calibrate? Repair? Adjust? RST Engineering Owning 3 April 4th 05 01:41 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 01:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
