Removing Decals
Old September 5th 05, 10:23 PM
Juan Jimenez
"UltraJohn" wrote in message
k.net...
Juan Jimenez wrote:
No, Bisbee, no one was talking to you. The only one who has crashed
around
here is one of your own gaggle. Besides, what are you talking about, you
can't even keep a marriage together, let alone an airplane. Shoo. Get
over
it.
You have to fly it first to be able to crash it!
John
Good point. did you hear that, frisbee?
  #72
Old September 5th 05, 10:26 PM
Juan Jimenez
This is a UseNet Newsgroup. We all talk to each other, and to
whomsoever reads the archives later, each time we post.
No, in _this_ planet we point out when people should keep their mouths shut.
BTW, Mr Jimenez, you mentioned that your engine was lighter than that
used in the other BD4Js. Others have suggested that it is lighter
by virtue of not having an integral starter.
There are no BD-4J's. It's a BD-5J. The 022 Couguar weighs 68 lbs soaking
wet. It has no starter/generator.
How hard is it to start the engine?
Not hard at all. Ignition on, fuel pump on, 145 psi, wait for 11-13% N1,
fuel solenoid valve on, light off.
Juan
  #74
Old September 6th 05, 10:20 PM
Hmm, shifts the CG forward a tad reducing the counterweight
needed up front, and thereby the total weight by a bit more too,
right? Or don't the 5js need a forward counterweight.
OK, what's 'N1'?
And what happens next after 'light off'?
FF
  #76
Old September 7th 05, 03:14 AM
Juan Jimenez
That's a very good observation. Yes, it does. On most BD-5J's you are
required to have some type of ballast on the nose, usually lead bars. On
Bishop's jets, the ones being used for surrogate cruise missile work for the
military, we resolved this by replacing the huge NICAD batteries with gel
cells and moving them forward behind the panel. We also moved just about
everything else that could fit in there. The specialists who did the
installation said they had never before managed to fit 2 pounds of **** in a
1 pound box. I can send you pictures of that installation if you like, it's
amazing. I designed the panel layout but the real work was done by the
installers.
OK, what's 'N1'?
N1 is the turbine rotation speed, expressed in percentage. This is a
plain-jane turbojet.
Watch your EGT, don't let it go too high, slowly bring the RPM up to a
stabilized idle around 51-55%. Make sure everything's in the green. It's
really a very simple setup.
Juan
  #78
Old September 7th 05, 03:48 AM
stabilized idle around 51-55%. ...
And after that?
FF
  #79
Old September 7th 05, 06:11 AM
Dan, U.S. Air Force, retired
Juan Jimenez wrote:
"Dan, U.S. Air Force, retired" wrote in message
news:YxoTe.9697$dm.8569@lakeread03...
N1 is turbine one in a two spool engine, N2 would be spool 2. He's
using the term to impress us since his motor is single spool.
Doubtful, Frisbee. That's your style, not mine. N1 is the term for turbine
RPM speed used in all single-spool turbines.
Get over it.
Juan
I worked on several jets with single spools. Not one used N1, it was
simply RPM.
Removing water repelent from fiberglass lay-up? Roger Home Built 2 December 2nd 04 11:15 PM
You can now by water-slip inkjet decals by the sheet Charlotte Gaisford Restoration 0 November 8th 04 02:00 PM
You can now by water-slip inkjet decals by the sheet Charlotte Gaisford Aviation Marketplace 0 November 8th 04 01:59 PM
Removing old antennas Jay Honeck Owning 30 March 21st 04 04:34 PM
Info needed to make decals for missiles TJ Simulators 1 January 16th 04 02:29 PM
