Removing Decals
Old September 7th 05, 06:11 AM
Dan, U.S. Air Force, retired
Juan Jimenez wrote:
"Dan, U.S. Air Force, retired" wrote in message
news:YxoTe.9697$dm.8569@lakeread03...
N1 is turbine one in a two spool engine, N2 would be spool 2. He's
using the term to impress us since his motor is single spool.
Doubtful, Frisbee. That's your style, not mine. N1 is the term for turbine
RPM speed used in all single-spool turbines.
Get over it.
Juan
I worked on several jets with single spools. Not one used N1, it was
simply RPM.
Old September 9th 05, 11:56 PM
Juan Jimenez
newsEuTe.9726$dm.6283@lakeread03...
simply RPM.
Nothing I can do about ancient history.
Removing water repelent from fiberglass lay-up? Roger Home Built 2 December 2nd 04 11:15 PM
You can now by water-slip inkjet decals by the sheet Charlotte Gaisford Restoration 0 November 8th 04 02:00 PM
You can now by water-slip inkjet decals by the sheet Charlotte Gaisford Aviation Marketplace 0 November 8th 04 01:59 PM
Removing old antennas Jay Honeck Owning 30 March 21st 04 04:34 PM
Info needed to make decals for missiles TJ Simulators 1 January 16th 04 02:29 PM
