Autorotation
Old September 9th 05, 02:00 PM
Steve R
"The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in
message ...
On Thu, 8 Sep 2005 16:35:41 +0100, "Beav"
"Steve R" wrote in message
Which angle are you asking for?
Do you want to know what the blades actual AoA (angle of attack) is or
do
you want to know what the blades angle of incidence is?
My guess would be he wants the angle as measured on the ground like we'd
do
on an RC heli. So incidence, not AoA.
I'm willing to bet he's an RC flyer too coz they're the only ones who want
to know that info :-))
As it happens, I'd be interested in knowing what the incidence angle is
with
the lever fully lowered and the heli sat on the floor. I know it's nothing
like as negative as we can usefully make use of on RC machines, but
there's
probably an optimum static setting for each type of heli.
I'd be interested in seeing this data measured at various points along
the blade to get an idea of the twist various manufacturers employ to
avoid tip stalls...
I've read that autogiros generally fly with a fixed incidence setting of +2
to +3 degrees. I'd assume that helicopters, in a steady state autorotation
would be somewhere close to that. However, autogiros do nothing but
autorotate so I'd think that their rotor blades would be optimized for that.
Since helicopters power their rotors, they use different airfoils and the
optimum pitch settings may be different.
As to collective full down incidence settings, I've been told that 0 degrees
is pretty much it. One person told me that some ships are set as low as -1
but that's only to assist in rpm recovery if the pilot gets sloppy and lets
the rpm's degrade to much. To hold that setting for too long would
overspeed the rotor system. I have no idea if any of that is true or not.
Kevin, I don't think that blade twist is used to prevent tip stalls. My
understanding is that having it improves the efficiency of the rotor system
at or near hover. The trade off is that it compromises cruise performance.
It all depends on what the machine is designed to do.
Do you have a reference on the tip stall point? I'd be interested in
learning more on that if I've got this wrong.
Fly Safe,
Steve R.
Power Off Touchdown Autorotation SelwayKid Rotorcraft 30 December 22nd 04 08:54 PM
First Full down Autorotation Hennie Roets Rotorcraft 6 October 27th 04 06:26 AM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 06:11 AM
Why do gyros use tilt head rather than swashplate Phillip Rotorcraft 28 August 5th 03 08:11 AM
