How about a slinger followed by a felt seal? The slinger can be made
from an o-ring. Felt will catch any tramp oil, is cheap, & can run dry. |
![]() If you have a homebuilt aircraft, consider this: Pull the plugs from the engine. Put your ear on the pump. Have someone slowly turn the prop. Listen to the vanes inside the pump fall from the inside to the outside of the rotor slot. There should be a regular "click" as each or the six, ( I think that there are six) vanes fall. If you do not hear the vanes fall, they most likely are "hung up" due to some contamination. Open the pump, and clean everything. Put it back together. I use a little silicon seal to act as a gasket on the back joint of the pump. I think that the pumps fail when the vane gets sticky and refuses to slide in and out of the slot in the rotor. I know that the slots in the rotor will wear larger eventually, but I listen to my pump every 25 hours at the oil change and have had to clean the pump twice in the last 250 hours. The pump now has about 800 hours on it. Good luck. On 21 Sep 2005 14:03:08 -0700, "nrp" wrote: How about a slinger followed by a felt seal? The slinger can be made from an o-ring. Felt will catch any tramp oil, is cheap, & can run dry. Zenith CH-300 Driver. |
Tim,
Wish you posted this before. I kind of suspected possibly cleaning it but was afraid of messing it up. I sent it back to Rapco who refused to warranty service it but gave me a discount deal on a new replacement pump. Tim Hickey wrote: ..... If you do not hear the vanes fall, they most likely are "hung up" due to some contamination. Open the pump, and clean everything. Put it back together. I use a little silicon seal to act as a gasket on the back joint of the pump. I think that the pumps fail when the vane gets sticky and refuses to slide in and out of the slot in the rotor. I know that the slots in the rotor will wear larger eventually, but I listen to my pump every 25 hours at the oil change and have had to clean the pump twice in the last 250 hours. The pump now has about 800 hours on it. ..... |
from an o-ring. Felt will catch any tramp oil, is cheap, & can run dry. The felt will wear. It's used in many older aircraft wheel bearings (even some newer ones, and it doesn't work that well. It has to be saturated with grease to prevent water uptake, and thereby attracts dust. If it soaked up oil it would become saturated and allow the oil past. Autos and trucks abandoned felt seals in the '40s and '50s. Dan |
Problems with Rapco dry vacuum pumps. | abripl | Home Built | 28 | September 25th 05 05:29 AM |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Wet Vacuum Pumps | DBlumel | Home Built | 4 | August 19th 04 08:27 AM |
Dual vacuum pumps bad news | Javier Henderson | Owning | 3 | May 7th 04 09:06 PM |
Low vacuum at idle | Chad Lemmen | Owning | 1 | August 18th 03 09:24 PM |
