Taxi Clearance
Old September 25th 05, 08:08 PM
Chris
"Brenor Brophy" wrote in message
I'm based in California, but I've flown from controlled fields in both
Ireland (EIWF) and Sweden (ESSB) and I never had to get an engine start
clearance. So I'm not so sure that this is a pan European thing.
-Brenor
It depends on each airfield and how they want to organise things, therefore
it is important to either read the latest airfield information or check out
the ATIS before start.
Old September 25th 05, 09:20 PM
Patrick Mayer
They seem to have a rigid system of airways between city pairs so ground
holds are fairly common.
more important: the slots at the airports! Sometimes, it's so crowded they
don't let you take off because they know traffic at your destination is too
heavy for you to fit in :-/
Pat
Old September 26th 05, 03:37 AM
Steven P. McNicoll
"Lynne" wrote in message
I think what you are forgetting is that the AIM is not regulatory. From
the looks of it, it is as if you're expecting to get a violation if you
start your engine prior to calling ground. That just won't happen.
This thread has gotten out of hand. The bottom line is that if you
start your engine, then get your clearance, then call ground, it may
end up wasting your time with the engine running if there are delays.
But, no matter what, you will never get in "trouble" for starting your
engine prior to getting the clearance, or talking to ground.
Or, in other words, there's no requirement to call ground prior to engine
start.
Old September 26th 05, 08:31 PM
Dave Butler
john smith wrote:
I always call on the handheld to get my clearance prior to engine start.
That way, if there is a delay, I am not paying to keep the engine
running while I wait.
That's a difference between an owner and renter mindset. I always start first to
give the oil a little more time to get limbered and warm.
Old September 26th 05, 08:34 PM
Dave Butler
Santa Monica (KSMO) requires you to call ground prior to engine start.
So just how do they require that?
- CURFEW: NO ENGINE STARTS OR DEPS EXPECT PPR LIFEGUARD FLTS 2300-0700 MON-FRI
AND 2300-0800 WKENDS.
Old September 26th 05, 09:23 PM
Steven P. McNicoll
"Dave Butler" wrote in message
news:1127763096.162487@sj-nntpcache-5...
MON-FRI AND 2300-0800 WKENDS.
The tower is closed during those hours.
Old September 29th 05, 05:20 AM
Dave S
So.. if the ATIS says "contact ground/clearance" prior to engine start,
does that constitute instruction from "air traffic control" which must
be complied with except in an emergency?
and is not obtaining (and complying with any instructions on) the ATIS
failure to obtain all relevant information regarding the proposed flight?
Can you reconcile these concepts (loosely paraphrased from the part 91
rules regarding ops) with what you are saying that there is "no
requirement to call ground prior to engine start" when in some
circumstances there appears to be?
Dave
start.
  #28
Old September 29th 05, 01:57 PM
Steven P. McNicoll
"Dave S" wrote in message
k.net...
does that constitute instruction from "air traffic control" which must be
No. FAR 91.123(b) states, "Except in an emergency, no person may operate an
aircraft contrary to an ATC instruction in an area in which air traffic
control is exercised." Ramps are not areas in which air traffic control is
exercised. Note that a taxi clearance is only required to operate on a
runway or taxiway. If I can taxi on a ramp without contacting ground
control I can certainly start an engine without calling them.
Not obtaining it might be, not complying with it is not.
If there is a requirement to call ground prior to engine start it will be
found in the FARs. You will find no such requirement there.
The local flying field here has a statement on the ATIS telling departures
to five specific airports to advise ground control five minutes prior to
engine start. It's for flow control purposes, the five airports are those
for which a flow release is required. The only penalty for not calling
ground prior to engine start is the potential fuel wasted on the ground
waiting for the release time.
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Touch and Goes versus Full Stop Taxi Backs Kevin Dunlevy Piloting 81 September 18th 05 09:26 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
