![]() "Michael" wrote in message ups.com... The real hazard, though, is not that the system that the pilot is depending on will fail. These are fairly new airplanes, and those systems are reliable. They're not failing a lot. The real problem is that the system only does what it's built to do. Training makes a pilot better overall. Substitute systems for training, and you better hope you have systems to do EVERYTHING the pilot does, because without the training, you will have an inferior pilot. Michael I have kept out of this debate but the above raises a significant opportunity. I don't know what exists yet in the US, but in Oz there is some classroom training associated with flying the Cirrus however I am unaware of any "glass cockpit" course per se. Our regulator has kept the syllabus to the days of rag and string and pommie motors, with a lot of emphasis on technical matters of no real use. What is needed is a part of the syllabus / course / book on the management and use of the glass cockpit, based around the current Avidyne/Garmin gear. It's the way of the future and training should respond accordingly to assist pilots to make the transition. Particularly us "matures" as the next generation will be flying these cockpits as the norm. Brian |
Cambridge 302 learning curve cont. | Tuno | Soaring | 4 | July 5th 04 10:10 AM |
C182 Glass Panel | Scott Schluer | Piloting | 15 | February 27th 04 03:52 PM |
learning curve in fs 2002.. | David Ciemny | Simulators | 5 | December 30th 03 12:18 AM |
18m polar curve | Alan Irving | Soaring | 1 | December 15th 03 11:45 PM |
Lesson in Glass | JimC | Owning | 3 | August 6th 03 01:09 AM |
