![]() "Morgans" wrote in message ... "Cy Galley" wrote Why not buy a straight pair and heat and bend to your specs? The way I am seeing his question, the action of plyers, with a typical pivot point, would only make the gripping surfaces slide past each other, and not grip anything. It seems like what is needed is a new type of tool, with a right angle on the end, and a screw pushing the other grip towards the right angle one. -- Jim in NC Go to Home Depot. I have a pair that I use quite often. The angle isn't quite 90o, but close enough. The jaws are much thinner than the usual vise-grip pliers; more like a long-nose pliers, bent at an angle in the same plane as the handles. I have not seen any vise-grip type pliers that have the jaws bent at an angle to the plane of the handles. I did find that if one tried to apply too much pressure, the jaws would slip out of alignment. The regular vise-grip pliers can exert quite a force, if needed, but the angled, "long nose", type can only exert a moderate force. I cannot check the brand / model because it is packed away pending a move out of state. Michael Pilla |
![]() Michael Pilla wrote: The way I am seeing his question, the action of plyers, with a typical pivot point, would only make the gripping surfaces slide past each other, and not grip anything. It seems like what is needed is a new type of tool, with a right angle on the end, and a screw pushing the other grip towards the right angle one. Uh, don't they call those monkey wrenches? Maybe they have another name for the small ones. -- FF |
ups.com... Michael Pilla wrote: The way I am seeing his question, the action of plyers, with a typical pivot point, would only make the gripping surfaces slide past each other, and not grip anything. It seems like what is needed is a new type of tool, with a right angle on the end, and a screw pushing the other grip towards the right angle one. Uh, don't they call those monkey wrenches? Maybe they have another name for the small ones. -- FF All my monkey wrenches are tightened via a knurled screw whereas the vise-grip pliers are tightened by squeezing the handles over center after adjusting the approximate grip range; rough description. Michael Pilla |
![]() Michael Pilla wrote: wrote in message ups.com... Michael Pilla wrote: The way I am seeing his question, the action of plyers, with a typical pivot point, would only make the gripping surfaces slide past each other, and not grip anything. It seems like what is needed is a new type of tool, with a right angle on the end, and a screw pushing the other grip towards the right angle one. Uh, don't they call those monkey wrenches? Maybe they have another name for the small ones. -- FF All my monkey wrenches are tightened via a knurled screw whereas the vise-grip pliers are tightened by squeezing the handles over center after adjusting the approximate grip range; rough description. Aha! The tool could have monkey-wrench planiform with a locking-grip (vice-grip TM) mechanism combining the best features of both tools. So, who wants to do the patent search? -- FF |
37 Degree Single vs Double Flared Tubing | Craig Foster | Home Built | 1 | July 21st 04 03:24 PM |
37 degree fitting | Ernest Christley | Home Built | 8 | June 17th 04 03:29 AM |
90 Degree turn while slipping | ISoar | Soaring | 40 | February 14th 04 10:49 AM |
Advice on flying Pitts with Haigh Locking Tailwheel | Ditch | Home Built | 19 | January 4th 04 10:18 PM |
