On Sun, 16 Oct 2005 09:08:19 -0600, Newps wrote
in :: The only thing wrong with it right now is the left bladder leaks when you fill it to the top so I'll fix sometime before next summer. Is it prudent to operate your aircraft with such a known defect? One would guess that the rubber near the connection to the filler neck has deteriorated to the point that it is cracked and lost its integrity. If that is a correct diagnosis, wouldn't it be possible for the bladder to completely separate from the filler neck in the event of air turbulence, and spill its flammable contents into the wing permitting it to run into the fuselage and cabin? Just a thought. If there is evidence of one rubber fuel bladder rotting, it may be prudent to consider the other rubber components of the fuel system being in a compromised condition. I would dearly miss your wry comments if anything should cause you not to be able to participate in this forum. |
![]() Larry Dighera wrote: On Sun, 16 Oct 2005 09:08:19 -0600, Newps wrote in :: The only thing wrong with it right now is the left bladder leaks when you fill it to the top so I'll fix sometime before next summer. Is it prudent to operate your aircraft with such a known defect? One would guess that the rubber near the connection to the filler neck has deteriorated to the point that it is cracked and lost its integrity. If that is a correct diagnosis, wouldn't it be possible for the bladder to completely separate from the filler neck in the event of air turbulence, and spill its flammable contents into the wing permitting it to run into the fuselage and cabin? Just a thought. If there is evidence of one rubber fuel bladder rotting, it may be prudent to consider the other rubber components of the fuel system being in a compromised condition. I would dearly miss your wry comments if anything should cause you not to be able to participate in this forum. These rubber bladders in Bonanzas develop small leaks in the upper outboard corner. If you fill it up it will leak out a gallon or so and then stop. Since it is not summer and I never fill my tanks except for a long cross country repairing this is not critical. |
Flying a Bonanza | Larry Dighera | Owning | 28 | September 10th 05 09:33 PM |
Wondering about Beechcraft V-tail Baron/Two engine Bonanza? | tigglys | Piloting | 14 | June 8th 05 01:45 AM |
IFR Bonanza F35 40.9K | Leo Liebl | Aviation Marketplace | 0 | June 12th 04 07:42 PM |
Looking for Bonanza N4252D | Hayden McKaskle | Owning | 5 | October 18th 03 02:48 AM |
Early Bonanza or Apache? | Brinks | Owning | 11 | July 16th 03 06:01 PM |
