Thank you all for the great answers.
I didn't say the prop stopped because of battery failure or starter failure. It could be from too rich mixture or switching to an empty fuel tank. I know, if you do something and the engine quits, turn the switch back immediately. Thanks again folks ".Blueskies." wrote in message ... wrote in message ... I was just wondering if best glidespeed in say a cessna 152 will be fast enough to get the engine started if you encountered a battery failure or starter failure. shywon Why would the prop stop in the air with a battery or starter failure? |
There's the other point: isn't glide range extended in a 172 if the
prop isn't windmiling? |
Tony wrote:
There's the other point: isn't glide range extended in a 172 if the prop isn't windmiling? It is in any aircraft. Stefan |
Tony wrote:
There's the other point: isn't glide range extended in a 172 if the prop isn't windmiling? It is in any aircraft. Stefan You'll start another windmilling argument with that. There are some serious divisions over whether to stop a prop or not to get more range after an engine failure. When we stopped the prop on the 150, the airplane's attitude was more nose-down to maintain the same glide speed, and the rate of descent was higher. The theory here is that the much higher angle of attack on the prop blades when stopped causes more drag that if it's windmilling. Dan |
prop isn't windmiling? Remember that picture in the different aviation rags several years ago of the Mooney with the feathered prop? Anyone remember what the add was for? |
Tony wrote:
There's the other point: isn't glide range extended in a 172 if the prop isn't windmiling? Yes, but you will lose a lot of altitude slowing down to get it stopped. Empirical experiments show that, if you're lower than about 6,000' above your target landing point, you're better off trimming for best glide and letting it windmill. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
Best Glide Speed | john smith | Piloting | 5 | September 4th 04 10:04 AM |
GPS glide ratio calculations | james | Soaring | 0 | May 4th 04 09:00 PM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
Speed Astir | Guy Acheson | Soaring | 0 | December 11th 03 02:24 AM |
Here's a silly question regarding plans | David Hill | Home Built | 21 | October 8th 03 04:17 AM |
