#11
On Fri, 21 Oct 2005 05:38:56 -0400, Michael Horowitz
wrote: What pressure is a coated fabric subjected to to determine if it has deteriorated? - Mike mike I have seen a guy try to repair a wing that his arm went through just leaning near it. you gotta stop pussyfooting around with fabric. make your hand into a "bird" walk down the side of the aircraft and whang that finger into the fabric as hard as your finger can stand. if it ever goes through you just saved yourself from a midair breakup. aircraft fabric in serviceable nick is pretty damn resilient. there is a video somewhere of a kid at oshkosh bouncing on a fabric wing like a trampoline. I'm pretty sure it actually didnt damage the wing. next time you are in flight you should rest your hand against a section of fuselage fabric. you'll be truely surprised at how much it moves around. fabric safety isnt about "its just 1 pound over the minimum strength so I'll get another 3 months and 2 days out of it" its about making sure that in turbulence at VNE in a steep turn nothing even looks like coming adrift.(thats what you need to be testing for) if you are buying an aircraft and the owner hasnt the confidence that it will withstand a robust "birding" then that guy has just admitted something and you should turn tail and walk away. I get asked on occasion about fabric testing since I fly a fabric covered aircraft (among a field which is overwhelmingly aluminium) and I demonstrate a robust birding to the point that the guy winces at the possible consequences. I'm actually only testing the Stits fabric to about half it's strength. If it ever breaks he's just saved my neck. have a look in AC43-13 at the table on page 2-2. 56psi if vne over 160mph 46psi for slower aircraft. ....but dont kid yourself that those figures may always be safe. Stealth Pilot |
Thanks for the pointer; I"ll give her a look.
I don't think I could run from an irate seller, so I'll probably end up leaving the testing to an A&P - Mike Stealth Pilot wrote: On Fri, 21 Oct 2005 05:38:56 -0400, Michael Horowitz wrote: What pressure is a coated fabric subjected to to determine if it has deteriorated? - Mike mike I have seen a guy try to repair a wing that his arm went through just leaning near it. you gotta stop pussyfooting around with fabric. make your hand into a "bird" walk down the side of the aircraft and whang that finger into the fabric as hard as your finger can stand. if it ever goes through you just saved yourself from a midair breakup. aircraft fabric in serviceable nick is pretty damn resilient. there is a video somewhere of a kid at oshkosh bouncing on a fabric wing like a trampoline. I'm pretty sure it actually didnt damage the wing. next time you are in flight you should rest your hand against a section of fuselage fabric. you'll be truely surprised at how much it moves around. fabric safety isnt about "its just 1 pound over the minimum strength so I'll get another 3 months and 2 days out of it" its about making sure that in turbulence at VNE in a steep turn nothing even looks like coming adrift.(thats what you need to be testing for) if you are buying an aircraft and the owner hasnt the confidence that it will withstand a robust "birding" then that guy has just admitted something and you should turn tail and walk away. I get asked on occasion about fabric testing since I fly a fabric covered aircraft (among a field which is overwhelmingly aluminium) and I demonstrate a robust birding to the point that the guy winces at the possible consequences. I'm actually only testing the Stits fabric to about half it's strength. If it ever breaks he's just saved my neck. have a look in AC43-13 at the table on page 2-2. 56psi if vne over 160mph 46psi for slower aircraft. ...but dont kid yourself that those figures may always be safe. Stealth Pilot |
Cy -
When an A&P does a test, does he have to be prepared to repair any damage he might do i.e. crack the paint or punch a hole? - Mike "Cy Galley" wrote: Look in AC 43.13-1B for fabric testing parameters. |
The beauty of the Maule tester is that there isn't a hole IF the fabric
passes. There can be some very minimal paint damage which is easily fixed. If the hole punches below the minimum level, then the fabric should be removed and replaced as it doesn't meet safe strength levels. If one continues the test to a higher level until it punches a hole, just a drop of paint to fill the hole can be used. "Michael Horowitz" wrote in message ... Cy - When an A&P does a test, does he have to be prepared to repair any damage he might do i.e. crack the paint or punch a hole? - Mike "Cy Galley" wrote: Look in AC 43.13-1B for fabric testing parameters. |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Ford V-6 engine work | Corky Scott | Home Built | 19 | August 21st 03 12:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Maule Turbine | kevin | Owning | 16 | August 4th 03 10:49 PM |
