Degaussing a Warrior
Old November 3rd 05, 11:10 AM
DavidM
Default Degaussing a Warrior
Drew Dalgleish wrote:
Maybe you should just give up and get a vertical card compass with a
remote sensor out in a wing tip.
Using a remote sensor (probably in the tail rather than the wingtip) is
my fallback, if everything else fails. I'm not sure whether an STC
would be required for that.
All the best,
David
Old November 3rd 05, 01:32 PM
Denny
WIth the flux meter and a Color TV degausser coil, you should be able
to cure it... Even a compass will help you pick out the magnetized
areas in the engine compartment for giving the buzz treatment... The
key to using the degausser is to buzz the part and keep the power on
while you withdraw the coil, not put the coil against it and just turn
the power on and off...
denny
Old November 3rd 05, 05:04 PM
Denny wrote:
: WIth the flux meter and a Color TV degausser coil, you should be able
: to cure it... Even a compass will help you pick out the magnetized
: areas in the engine compartment for giving the buzz treatment... The
: key to using the degausser is to buzz the part and keep the power on
: while you withdraw the coil, not put the coil against it and just turn
: the power on and off...
I'll agree that the tv degausser will likely be able to do it. With all the
decorations (like engine mount + engine), it might be tricky to get in where you need
it to be.
I'd recommend removing any/all things possible to reduce the risk of
magnetizing anything else.
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old November 3rd 05, 05:05 PM
Oh, and if space constraints make it difficult or impossible to gracefully
move away while running, you can probably use a variac to ramp the field up/down to
simulate moving the coil. That's how the degaussers in monitors work.
-Cory
* Cory Papenfuss *
Old November 3rd 05, 05:34 PM
Darrel Toepfer
How about a tape eraser? Would be easier to get into tight places...
Old November 3rd 05, 11:03 PM
Mike W.
Yes, a bulk tape eraser will work.
"Darrel Toepfer" wrote in message
Old November 6th 05, 06:26 PM
Both Canadian and American law require a nonstabilized magnetic
direction indicator that isn't dependent on the aircraft's electrical
system. The remote systems don't qualify. I wish they did, as the mag
compass can be a real pain to calibrate in any airplane that has
miscellaneous magnetic fields in it.
Dan
Warrior cruise RPM settings lardsoup Piloting 35 October 9th 05 11:59 PM
Fuel dip tube for Piper Warrior? TTA Cherokee Driver Owning 16 May 3rd 04 05:42 PM
Warrior POH Michael Egan Owning 2 February 4th 04 05:41 PM
Warrior POH Michael Egan Piloting 2 February 4th 04 05:41 PM
Warrior Strobe Tube Replacement Jerry Malin Owning 3 September 29th 03 04:02 AM
