Other details: - Switching the Mags .... no change - Cutting out the Alternator ... no change - Turning off various equipment ... no change I did move ignition wires thru the insulators a bit to see if there was any change. After doing this, the noise went away for the most part. A test flight over central NJ for about 1 hour resulted in a burst of static that lasted about 15 seconds about 20 minutes into the flight. There are some occasional clicks here and there. It seems to vary with engine speed, attitude, etc. I will continue with the search. Thanks all. Ed Berberich |
Aircraft ignition leads are shielded in a coaxial cable. To suppress
RFI which would otherwise be radiated off the HV leads, the shield must be continuous (no breaks), and the shield must be electrically connected at both ends, plug and mag tower. Might be necessary to disconnect each lead (one at a time) at the plug end, and then use an Ohmmeter to make sure you have continuity from each dangling gland nut to the airframe. Similarly, the P leads running from the mags to the rear of the mag switch should be shielded to prevent RFI from being radiated. Their shields should be unbroken, and grounded to the mag body, and to the panel very close to where the mag switch is mounted. |
You may have worn through and broken the shield braid where it passes
through a hold down clamp or the baffles. If so the shield may not have full electrical conunity for the full length. Disconnect the plug end of the wire and hook a ohm meter to the plug nut and the other end to an engine ground. Now shake and pull the plug wire and see of the reading changes. It should read less than 0.3 ohms. If the shield is broken or worn through anywhere this leads to EM leakage which you can hear in the radio. On Thu, 03 Nov 2005 03:14:14 GMT, ECB wrote: Other details: - Switching the Mags .... no change - Cutting out the Alternator ... no change - Turning off various equipment ... no change I did move ignition wires thru the insulators a bit to see if there was any change. After doing this, the noise went away for the most part. A test flight over central NJ for about 1 hour resulted in a burst of static that lasted about 15 seconds about 20 minutes into the flight. There are some occasional clicks here and there. It seems to vary with engine speed, attitude, etc. I will continue with the search. Thanks all. Ed Berberich |
| Thread Tools | |
| Display Modes | |
| I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 06:39 PM |
| My Engine Fire!! | [email protected] | Piloting | 21 | April 2nd 04 06:02 PM |
| Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 05:09 PM |
| Motorgliders and gliders in US contests | Brian Case | Soaring | 22 | September 24th 03 01:42 AM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
