VG's on Warrior?
Old November 8th 05, 03:25 AM
Dave
Default VG's on Warrior?
Why VG's?
Well..
Lets call it "Margin"..
It appears from all reports, I "might" go a little faster (2 Knts),
"will" stall slower (5 knts) - (I will settle for a couple.)
decreased sink/increased climb, (150 fpm, I will be happy with 75.)
Shorter landing roll, shorter takeoff run and climb to alt over
obsts.
They are CHEAP!
And there is a significant performance increase with them from what
I have investigated, if I get 30% of what some tell me they are
getting, I happy..
So... margin. - a little faster when needed, a little slower when
needed, a little shorter when needed, a little higher when needed, a
little farther when needed, a little better when loaded.
Maybe a little bit more of what I need when I need it really badly..
Worth the investment when needed.
And If I can duplicate a take off I have seen on video of a VG
equipped Cherokee,- he was over a 50 ft obst. while I would be
struggling for daylight.... Our warrior is no superstar, but it
"meets the numbers"
Seems like a lot for a few hundred bucks...maybe worth taking a chance
on...
Thanks to all for the thread of info...
Dave
On Sun, 06 Nov 2005 21:56:16 -0500, zatatime wrote:
On Sun, 06 Nov 2005 20:05:50 -0400, Dave
OK, after a lot of research, we are looking at installing AMR&D's
Vortex Generators on our Warrior..
Anybody out there with expirence with these?
Dave
Why did you decide you wanted to do this?
z
Old November 8th 05, 01:28 PM
: Seems like a lot for a few hundred bucks...maybe worth taking a chance
: on...
: Thanks to all for the thread of info...
: Dave
As I said, my personal experience on three different 160 or 180 hp's
stubby-winged Cherokees is consistent... they help a lot more than one would think at
the low end. Nothing substantial at the high speed end.
One other detail. I believe that AM said that they are NOT approved for stock
wintips. He said some aftermarked tips were necessary... whether it be hoerner style
or droop-tip... doesn't matter. They do the same (although the droop-tips on my bird
look a bit silly. Make it look like the "bat-plane"). Stock tips on the Hershey-bar
cherokees are awful from what he said.
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old November 8th 05, 02:14 PM
Jay Honeck
would think at
One thing no one has mentioned: Art Mattson's VGs are bigger than most.
Although there are fewer of them than on most applications I've seen, they
look wickedly dangerous to me. (As in sharp.) Cleaning around them has got
to be a real pain, especially if you slip and slice your wrist on one of
them.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 9th 05, 12:21 AM
Dave
Hi Cory!
I called Art today for just that clarification..(the clearest
and fastest water is usually at the head of the stream)
Better wingtips are needed on the straight wing, NOT needed on
the Warrior (tapered ) wing...
Aileron gap seals are recommended....
With the straight wing, the improvement in the flying quality
of the root sections carries some risk as the tips don't do so well
by comparison.
With the taper aka Warrior wing, Piper "fixed" the outer wing
panels, and they do just fine with the VG's installed..
Gap seals are to increase the roll authority at the lower
speeds capable with the VG's.
The guy makes sence to me... answered all my questions well
and to my satisfaction.Explained why he did the mods the way he did ,
did NOT make any outlandish claims, and outlined the possible
negative issues.
Looks like gap seals for ailerons and stab trim, and the VG's
for us..
New paint and interior 1st.
Dave
On Tue, 8 Nov 2005 13:28:43 +0000 (UTC),
: on...
: Dave
-Cory
* Cory Papenfuss *
Warrior cruise RPM settings lardsoup Piloting 35 October 9th 05 11:59 PM
Flying to Cancun from KeyWest in a Warrior. Piperflyer Piloting 6 September 29th 04 07:26 AM
Fuel dip tube for Piper Warrior? TTA Cherokee Driver Owning 16 May 3rd 04 05:42 PM
Warrior POH Michael Egan Owning 2 February 4th 04 05:41 PM
Landing a warrior Dan Moos Piloting 27 August 17th 03 11:05 PM
