Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Why does a prop ice up so apparently readily?
Old November 8th 05, 08:27 AM
Peter Duniho
Default Why does a prop ice up so apparently readily?
"Peter" wrote in message
These two things combined with the fact that the
prop has a high collection efficiency because of its thin cross section
This I don't see - as it happens, the SOP for this turboprop when in
icing conditions is to go max revs, the reason being that the less the
AOA the less ice will be picked up. They also go 10-15-deg flaps for
the same reason - it reduces the wing AOA.
Changing the AOA doesn't alter the cross-section of the prop. Thinner
airfoils DO accrete ice faster than thicker ones, even as airfoils at higher
AOA accrete ice faster than airfoils at lower AOA.
Pete
Old November 8th 05, 01:51 PM
Stubby
Intuitively, using flaps to get a bit of lift means the wings have to
do a bit less. So, you can fly at a slower speed and get the required
lift. A slower speed means less humid air flows over the wing per unit
time. As a result less ice per unit time will be formed on the wings.
Same for the prop setting. You want to use the "climb" (max revs)
setting so that the wings don't have to contribute as much lift at a
given speed.
That being said, you simultaneously want to minimize your flight time to
allow the minimum time for ice to accumulate.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
my ignorance LCT Paintball Home Built 25 April 9th 05 06:54 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
