IVO prop dyn. balancing
Old November 7th 05, 03:45 PM
abripl
Default IVO prop dyn. balancing
I got a IVO magnum prop in-flight adjustable - no spinner. Did anyone
do a dynamic balance on one of these?
SQ2000 canard http://www.abri.com/sq2000
Old November 8th 05, 03:09 AM
stol
I rebalance mine every time I switch blades or any combination. They
are real close right from Ivo but the last touch of precise balancing
makes it VERY smooth.... I get mine done at Jackson Hole Aviation. Most
good FBO'S have a dynamic balancer..
Ben
www.haaspowerair.com
Old November 8th 05, 04:30 AM
abripl
I don't have a spinner on mine. Where would you add the balancing
weights (washers)?
Old November 8th 05, 02:27 PM
stol
Hmmmm, If you are running the paddle blades you can slightly shorten
one to get it in balance because the paddle blades are blank on the
ends, if you are running the rounded blades then your only choice is to
place the weights under a prop bolt. I guess the question is,,,why no
spinner???
Old November 8th 05, 05:09 PM
spinner???
We had an IVO prop on a Glastar and couldn't get it to stay
balanced. The blades, being held by only two bolts each, can move (or
swing) chordwise in the hub just enough that the assembly ends up being
off-balance chordwise, and no amount of spanwise balancing will fix it.
Even with those bolts torqued to spec we had blade movement between the
plates. Fretting was evident on the blade bushings and mating plate
surfaces. Scared us.
Too bad, since the prop pulled well, better than the Warp Drive
that replaced it. The Warp was so much easier to balance but presented
more hassle when changing pitch.
Dan
Old November 8th 05, 10:29 PM
R&R Sherwood
swing) chordwise in the hub......
When ground testing my auto engine with an old style 3 blade IVO prop, I
took several still photos. Some of the photos appeared to show the blades
advancing or retreating much like that of a helicopter.....not sure if this
was a trick of the camera or actually happening. After about 10 hours of
ground time I found damage to the base of the blades. Now that the engine
is flying with an MT prop I have been unable to duplicate that effect in any
of my photos.
Russell Sherwood
Houston, TX
Old November 9th 05, 12:23 AM
of my photos.
The focal plane shutters used in many good cameras would give
that bent-prop effect. As the shutter gap moved across the plane,
either side-to-side or top-to-bottom, one side or edge of the film was
exposed before the other, so a rotating prop or rotor would be caught
over a rather long time, spread across the film, and would appear bent
or out of phase. I don't know that the IVO would move all that much,
unless it was flexing as well. I didn't like the IVO's thin-skinned
sandwich construction, either. Seemed to be a lot of load on very
little fiber and a lot of foam.
The aperture shutters found in smaller, cheap cameras wouldn't
"bend" rotating stuff.. Were you using the same sort of camera both
times?
Dan
Old November 9th 05, 02:06 AM
stol
I
blades
this
of
engine
in any
of my photos.
Russell Sherwood
Houston, TX
This is all VERY interesting.........Thanks for the feed back...
Ben
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
dynamic prop balancing George A. Graham Home Built 2 April 21st 05 01:20 PM
Prop balancing and assorted observations - long Dave Hyde Home Built 10 June 27th 04 01:08 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
