Lycoming Prop-Strike AD question
Old November 26th 05, 08:25 PM posted to rec.aviation.piloting
Default Lycoming Prop-Strike AD question
"BTIZ" wrote in message
news:wiShf.4943$pF.3133@fed1read04...
just replace the dang bolt... it's an easy fix and well worth the effort..
On our Pawnee, O-540 we did not even have to lift the engine off the
mounts.
Really?
What the f--- do I know. The 2 mechanics at the pre-purchase inspection
told me the 0-320-E2D engine on a Cardinal 177 1968 would have to be removed
and shipped to an engine shop to have the bolt and plate removed and
replaced.
Tien
Old November 26th 05, 09:07 PM posted to rec.aviation.piloting
Tien Dao wrote:
/snip/ The 2 mechanics at the pre-purchase inspection
replaced.
Tien
Tien,
Run, don't walk, away from that shop! Not only is it blatantly obvious
that the AD does NOT apply to that engine, in this case, but even if you
did want to go ahead and replace the bolt, it's a rudimentary procedure.
Any *competent* mechanic can accomplish this on the plane, in about a
day. I recommend you find a different mechanic/shop for your future needs.
Happy Flying!
Scott Skylane
Old November 26th 05, 10:48 PM posted to rec.aviation.piloting
"Scott Skylane" wrote in message
I`m gone! Thanks for the validation!
Tien
Old November 27th 05, 02:34 AM posted to rec.aviation.piloting
it needs to be replaced because the cardinal had a prop strike?
"Tien Dao" wrote in message
effort..
mounts.
Really?
removed
replaced.
Tien
Old November 28th 05, 11:58 PM posted to rec.aviation.piloting
news:PV8if.5029$pF.1981@fed1read04...
Yup. So bad that they trashed the prop and got a new one but didn`t tear
down the engine to check the crankshaft, gears bolts and all. No wonder. It
is due to guys like this that we read of engine failures, "accidents" and
fatalities giving the companies and FAA more reason to pile on more AD`s
that punish the guys who did a good job and followed the previous AD`s in
the first place.
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
my ignorance LCT Paintball Home Built 25 April 9th 05 06:54 PM
Sensenich Wood Prop Question [email protected] Owning 3 April 4th 05 02:32 PM
Lycoming 0-360 factory overhaul core charges - Does Air Powertell the truth ? Mike Spera Owning 6 December 13th 04 01:13 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
