PZL compass repair
Old November 27th 05, 11:13 PM posted to rec.aviation.soaring
Default PZL compass repair
Fellas,
I highly recommend a Hamilton vertical card compass, easily swung and
never a leak. I also like the planform display. I've given up on the
old style compass, always leaking and not legal to fix or refill
yourself. They're pricey, but once you buy it, you're done messing with
compasses.
Anubody ever had problems with a Hamilton?
www.jimphoenix.com
Old November 27th 05, 11:30 PM posted to rec.aviation.soaring
Yes, it wouldn't rotate more than about 120 degrees. Bought a new Airpath,
used solely as a backup should the GPS and moving map fail
Mitch Deutsch.
"jphoenix" wrote in message
snip
www.jimphoenix.com
Old November 28th 05, 02:52 AM posted to rec.aviation.soaring
A number of reports where the needle stuck and you have to tap the
instruments to free it. I have an Airpath 2300 but can't tell you the
last time I actually looked at it.
Tony V.
Old November 28th 05, 12:51 PM posted to rec.aviation.soaring
Hi Jim - I have had a Hamilton and replaced it with a PZL.
The Hamilton is, because of its design, very sensitive to
pitch attitude, and consequently quite inaccurate. This is
especially true at higher lattitudes with steeper dip. The
problem is that mechanically the sensing element can't
really stay level.
Pick a point on the horizon heading East or West. Note
the exact compass reading at 45 knots. Now stabilize the
airspeed at 110 knots and see what the compass reads.
It does look nice though !
Best Regards, Dave
Old November 28th 05, 01:51 PM posted to rec.aviation.soaring
Dave,
That's interesting, I'll give it a try. I'm at a higher latitude and I
do like to have a working compass just in case the un-thinkable happens
someday. Might have to put one of my old, leaky whiskey units back in.
Calibrate? Repair? Adjust? RST Engineering Owning 3 April 4th 05 01:41 PM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 03:09 AM
Strange compass behavior me Owning 10 February 14th 04 04:24 AM
Bubble Face Compass Repair Gene Hetsel Restoration 1 January 9th 04 04:59 AM
