* Ron Rosenfeld :
Hm... interesting. "optimum rate consistent with the operating characteristics of the aircraft". This is fuzzy. Nothing wrong with giving the pilot discretion over the rate of descent. However, there is a requirement to notify ATC if climb/descent rates will be less than 500 fpm. OK, that makes sense. Never heard of that requirement yet, thanks for that. Will check our regulations here about comparable requirements. You seem to be defining "optimum" as equivalent to "economic". I see no such implication in the US. Well, what other interpretations of "optimum rate of descend" would you have in mind? If they didn't have anything specific in mind, they could have written "any rate consistent with the operating characteristics". Which would be kinda superfluous as you should never climb/descend with a rate not being consistent with the operating characteristics. My definition of "optimum rate of descend" without further reference to the parameters for determination of optimality would be something along the lines of "the minimum rate of descend required to reach a destination altitude complying to all altitude and speed restrictions as well as maintaining target speed". This rate is of course a function of time, with the result being roughly what FMS computes for VNAV as well. :-) Well, Europe has to handle a lot fewer aircraft than does US ATC. So maybe hat's why they need more regulations. But wait, you stated that this is an "unwritten rule". So it's not a regulation, but merely an expectation. Yep. But compliance with that is quite universally as far as I'm told by controllers. :-) The AIM is available on line. Look at www.faa.gov for the publications. It is not regulatory, but its procedures are generally followed. Thanks! Best regards, Daniel |
On Mon, 28 Nov 2005 06:35:53 +0000 (UTC), Daniel Roesen
wrote: * Ron Rosenfeld : Hm... interesting. "optimum rate consistent with the operating characteristics of the aircraft". This is fuzzy. Nothing wrong with giving the pilot discretion over the rate of descent. However, there is a requirement to notify ATC if climb/descent rates will be less than 500 fpm. OK, that makes sense. Never heard of that requirement yet, thanks for that. Will check our regulations here about comparable requirements. You seem to be defining "optimum" as equivalent to "economic". I see no such implication in the US. Well, what other interpretations of "optimum rate of descend" would you have in mind? If they didn't have anything specific in mind, they could have written "any rate consistent with the operating characteristics". Which would be kinda superfluous as you should never climb/descend with a rate not being consistent with the operating characteristics. I typically climb in the neighborhood of a 1000 fpm and descend between 800 and 1200 fpm. If I have a descent to and cross at, I'll adjust the rate of descent to get me down within a mile or two of the crossing point. However if I'm kept "up there" too long, I'm not going to blow my, or my passengers ear drums with too fast a descent. If I'm at cruise, backing off on the throttle 5" will give me 500 fpm while the speed stays constant. If need be I can slow down a *bit* which will give me a steeper descent yet. However I prefer to keep the descent to about 800 and calculate how far out I need to start down. If I'm within a minute or two of my limits I'll call ATC and request to start down. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com My definition of "optimum rate of descend" without further reference to the parameters for determination of optimality would be something along the lines of "the minimum rate of descend required to reach a destination altitude complying to all altitude and speed restrictions as well as maintaining target speed". This rate is of course a function of time, with the result being roughly what FMS computes for VNAV as well. :-) Well, Europe has to handle a lot fewer aircraft than does US ATC. So maybe hat's why they need more regulations. But wait, you stated that this is an "unwritten rule". So it's not a regulation, but merely an expectation. Yep. But compliance with that is quite universally as far as I'm told by controllers. :-) The AIM is available on line. Look at www.faa.gov for the publications. It is not regulatory, but its procedures are generally followed. Thanks! Best regards, Daniel |
On Mon, 28 Nov 2005 06:35:53 +0000 (UTC), Daniel Roesen wrote:
Well, what other interpretations of "optimum rate of descend" would you have in mind? I I would take it to mean that you take into account all the factors involved, not just how much money you're going to spend/save. That would include, but not be limited to, operating characteristics of the aircraft, passenger comfort, ATC expectations, expense, visibility at the required angle of attack, etc. For example, in my Mooney, I would typically use a cruise climb of 115-120 KIAS rather than a best rate of climb of about 90 KIAS because of improved forward visibility at the lower AOA (unless ATC requested "best rate"). Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
you have in mind? Depends what one is trying to optimize. Money, turbulence, time enroute, arrival time (to coincide with an open gate), dive currency, there are many things that one can attempt to "optimize", though I'd agree that ATC is not likely to think of them all. ![]() Jose -- You can choose whom to befriend, but you cannot choose whom to love. for Email, make the obvious change in the address. |
"Daniel Roesen" wrote in message
... * Ron Rosenfeld : Hm... interesting. "optimum rate consistent with the operating characteristics of the aircraft". This is fuzzy. Nothing wrong with giving the pilot discretion over the rate of descent. However, there is a requirement to notify ATC if climb/descent rates will be less than 500 fpm. OK, that makes sense. Never heard of that requirement yet, thanks for that. Will check our regulations here about comparable requirements. You seem to be defining "optimum" as equivalent to "economic". I see no such implication in the US. Well, what other interpretations of "optimum rate of descend" would you have in mind? If they didn't have anything specific in mind, they could have written "any rate consistent with the operating characteristics". Which would be kinda superfluous as you should never climb/descend with a rate not being consistent with the operating characteristics. I believe FAAO 7110.183 has all the performance expectations for various aircraft from ATC's perspective. Good luck finding it.. I have a 6 year old version and cant find it online right now. -- Mike Teague - Vancouver WA, USA -- Opie and Anthony - XM202 - O&A Party Rock! -- Phil Hendrie = Radio Genius |
"Mike Teague" wrote in message
news ![]() "Daniel Roesen" wrote in message ... * Ron Rosenfeld : Hm... interesting. "optimum rate consistent with the operating characteristics of the aircraft". This is fuzzy. Nothing wrong with giving the pilot discretion over the rate of descent. However, there is a requirement to notify ATC if climb/descent rates will be less than 500 fpm. OK, that makes sense. Never heard of that requirement yet, thanks for that. Will check our regulations here about comparable requirements. You seem to be defining "optimum" as equivalent to "economic". I see no such implication in the US. Well, what other interpretations of "optimum rate of descend" would you have in mind? If they didn't have anything specific in mind, they could have written "any rate consistent with the operating characteristics". Which would be kinda superfluous as you should never climb/descend with a rate not being consistent with the operating characteristics. I believe FAAO 7110.183 has all the performance expectations for various aircraft from ATC's perspective. Good luck finding it.. I have a 6 year old version and cant find it online right now. Ahh, I found it, sorry, it's now appendix A in the 7110.65. -- Mike Teague - Vancouver WA, USA -- Opie and Anthony - XM202 - O&A Party Rock! -- Phil Hendrie = Radio Genius |
![]() Mike Teague wrote: "Mike Teague" wrote in message news ![]() "Daniel Roesen" wrote in message ... * Ron Rosenfeld : Hm... interesting. "optimum rate consistent with the operating characteristics of the aircraft". This is fuzzy. Nothing wrong with giving the pilot discretion over the rate of descent. However, there is a requirement to notify ATC if climb/descent rates will be less than 500 fpm. OK, that makes sense. Never heard of that requirement yet, thanks for that. Will check our regulations here about comparable requirements. You seem to be defining "optimum" as equivalent to "economic". I see no such implication in the US. Well, what other interpretations of "optimum rate of descend" would you have in mind? If they didn't have anything specific in mind, they could have written "any rate consistent with the operating characteristics". Which would be kinda superfluous as you should never climb/descend with a rate not being consistent with the operating characteristics. I believe FAAO 7110.183 has all the performance expectations for various aircraft from ATC's perspective. Good luck finding it.. I have a 6 year old version and cant find it online right now. Ahh, I found it, sorry, it's now appendix A in the 7110.65. -- Mike Teague - Vancouver WA, USA -- Opie and Anthony - XM202 - O&A Party Rock! -- Phil Hendrie = Radio Genius You like Phil Hendrie too? |
"Herb Sewell" wrote in message
oups.com... You like Phil Hendrie too? obviously.. heard from walter bellhaven lately? I hear he is doing lectures on botany in the day-room these days ![]() -- Mike Teague - Vancouver WA, USA -- Opie and Anthony - XM202 - O&A Party Rock! -- Phil Hendrie = Radio Genius |
No SID in clearance, fly it anyway? | Roy Smith | Instrument Flight Rules | 195 | November 28th 05 10:06 PM |
Taxi Clearance | Ron Rosenfeld | Instrument Flight Rules | 27 | September 29th 05 01:57 PM |
Clearance: Direct to airport with /U | Judah | Instrument Flight Rules | 8 | February 27th 04 06:02 PM |
Q about lost comms on weird clearance | Paul Tomblin | Instrument Flight Rules | 34 | February 2nd 04 09:11 PM |
Picking up a Clearance Airborne | Brad Z | Instrument Flight Rules | 30 | August 29th 03 01:31 AM |
