Hi,
I think PZL still produces instruments. There web site is he http://www.pzl.com.pl/en/produkty/os...wigacyjne.html or http://www.pzl.com.pl/ I sell the Airpath fluid filled compasses (extremely popular in all aircraft) and the PAI-700 vertical card compasses. I had one customer that said he loves the PAI-700 and would never use anything else in his gliders. The display is very intuitive - much easier to read at a glance than the Airpath compasses. http://www.soarmn.com/cumulus/compasses.htm Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "5Z" wrote in message oups.com... I have a PZL K-13 compass that's leaking. Here's a photo of the compass: http://www.soarbfss.org/scgi-bin/gal...0/acc.jpg.html This summer, I had the canopy of my ASH-26E open and it focused the sun onto the compass and melted a hole in the front. Luckily it was in the black painted area of the plastic, so I repaired it with some epoxy and then repainted it. I then fully filled it with compass fluid using the fill hole on the back. Unfortunately, it now leaks around the circular "base" of where the the plastic "bubble" is attached to the back. Maybe there's an O-ring seal in there? The back has two holes that I assume are for a spanner wrench and the ring attaching the plastic part to the base also has some notches that I suppose are for a special wrench as well. I've put a pair of "c clip" pliers in the holes on the back and tried to unscrew the outer ring by hand but it's too tight and I'm afraid to put too much pressure on it. Any suggestions either how to take it apart or where in the USA to send it? Thanks -Tom |
Hi,
I normally do not post about my instrument sales business, however, it seems I am the only supplier that has continued to stock the PZL K13a compass. The company that distributes this compass changed hands 2 years ago and the prices have been adjusted significantly. $389.00. This makes it the most expensive whisley compass on the market but it also has some unique features... size, mounting options, and quality. I have found that most of the leaking issues are due to burning a hole in it, or over tightening the mounting ring which causes a stress riser as the compass body expands when heated. If you have a PZL compass installed, you may want to check the tension on the band. Shoud just be snugged to hold it from slipping. The vertical card compasses are very sensitive to binding caused by mounting with a stress load. Many glider instrument panels are very thin with only 2-3 layers of light carbon cloth. When populated with a full complement of instruments, each instrument becomes a structural component. If the vertical card compass is one of these, there may be a chance that it will become disformed slightly especially with changes in temp thus it will hang up. It is easier to read when it is stuck!! Rex Williams Soaring Center |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Calibrate? Repair? Adjust? | RST Engineering | Owning | 3 | April 4th 05 01:41 PM |
Canopy crack repair | Pete Brown | Soaring | 0 | May 18th 04 03:09 AM |
Strange compass behavior | me | Owning | 10 | February 14th 04 04:24 AM |
Bubble Face Compass Repair | Gene Hetsel | Restoration | 1 | January 9th 04 04:59 AM |
