Do you have copper battery cables? My Warrior would disengage the gear like
you described until I got the copper cables put in. Marco Leon wrote in message ... Hey all. I'm pretty certain I've convinced myself that my "bad starter" and/or bad ring gear are actually my battery going bad. With the skytec starter, it makes sense that at high-load, the voltage could drop enough so the starter solenoid cannot hold the gear engaged to the flywheel. It pops back out while cranking on a compression stroke. So, what are the thoughts on the different batteries? I'm pretty sure mine is the old Gill G35. It's been in there for at least 3.5 years. Any good replacement ones that might save weight, etc? FWIW it's a 180hp O-360 so it is high compression. Thanks -Cory |
Marco Leon mmleon(at)yahoo.com wrote:
: Do you have copper battery cables? My Warrior would disengage the gear like : you described until I got the copper cables put in. : Marco Leon Yes, I've got the copper cables. I've checked the terminals and connections and they all seem to be in good shape. Looks can be deceiving however, so I'm planning on going out with an assistant and a voltmeter and track down all the voltage drops. With the Skytec starter, I never really had a problem with "cranking power." It's only the gear disengaging now that's making me suspect. If it turns out it is the battery and I replace it, I suspect I'll be surprised at how much *extra* cranking power I'll have. As things slowly degrade you forget what it used to do. The main reason I'm asking is because another friend of mine put a lightweight battery in his experimental. I don't know if it's available for certified. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Battery Question | [email protected] | Soaring | 19 | September 15th 05 01:38 AM |
14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 01:37 AM |
Battery Replacement and Cold Cranking Amps | O. Sami Saydjari | Owning | 27 | February 2nd 04 02:38 PM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 06:32 PM |
