: Cory,
: Use a good DVM, like a Fluke 75. Use clip leads to connect it between : the stud on the starter and the starter frame. Crank (mixture at : cutoff), and read the voltmeter. : If your voltage drops below 8V, find out why. : Repeat the test with the voltmeter leads connected directly to the : positive and negative poles of the battery. If the battery voltage : drops below about 10V, then replace the battery. If the battery voltage : holds above 10V, then use the voltmeter to do a binary search to find : where the big voltage drop is. Fix that. : Dont overlook that the voltage drop could be across the ground path : between the battery neagive pole and the starter frame. : Personally, I prefer the flooded cell batteries... Did that this afternoon. It was actually snowing pretty hard here in VA (I'm outside), so I wasn't too interested in mucking around under the cowling. Put the DMM's probes *ON* the battery lugs (to eliminate all connections). It read between 9.0-9.35V depending on whether or not it was cranking at a compression stroke or not. The battery read 12.4V IIRC before I cranked at all, so that'd be about a 75% SOC... definately good enough to roll over OK. I have not topped off the battery, but did a 2.5 hour cross country a week ago and it's been acting up for awhile now. Unless the charging system is broken it's gotta be the battery. The plane only has a loadmeter, not a voltmeter. Last time I checked the charging voltage, however, it was fine and the loadmeter's indications haven't changed since then. From what I measured, I see about a 1V drop across all the cabling and solenoids.... probably acceptable for such a long run. I suspect that PA-28's are extra susceptible to battery strength with such long runs. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
wrote)
Did that this afternoon. It was actually snowing pretty hard here in VA (I'm outside), so I wasn't too interested in mucking around under the cowling. We just got the word from Virginia that the nieces in Lynchburg will have 'no school' - it's called off because of the snowy forecast. Ages 8 and 10. Nothing in adult life equals a Snow Day as a kid. g Montblack |
Montblack wrote:
wrote) Did that this afternoon. It was actually snowing pretty hard here in VA (I'm outside), so I wasn't too interested in mucking around under the cowling. We just got the word from Virginia that the nieces in Lynchburg will have 'no school' - it's called off because of the snowy forecast. Ages 8 and 10. Nothing in adult life equals a Snow Day as a kid. g Not true Montblack!! A snow day for a child is NOTHING compared to a snow day for a TEACHER! I brought my books home and I'm chanting (north, south, east, west, snow is what we like the best!!!) (must be sung in your PJ's a 7:00 pm while facing north, taught to me by a principal!) Margy Montblack |
is what we like the best!!!) (must be sung in your PJ's a 7:00 pm while facing north, taught to me by a principal!) I don't know about the rest of you folks, but personally I would pay a fair amount of cold, hard cash just to see Margy do this... On Atlas' wing at OSH '06? ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
I brought my books home and I'm chanting (north, south, east, west, snow is what we like the best!!!) (must be sung in your PJ's a 7:00 pm while facing north, taught to me by a principal!) I don't know about the rest of you folks, but personally I would pay a fair amount of cold, hard cash just to see Margy do this... On Atlas' wing at OSH '06? ;-) Jay, What are you thinking?!?! Who wants snow at OSH? Sat home yesterday in front of a nice warm fire, 3 inches with a thin layer of ice on top. Enough to close for the day, which I am still sort of entitled to even though I'm at the museum. Margy |
| Thread Tools | |
| Display Modes | |
| Battery Question | [email protected] | Soaring | 19 | September 15th 05 02:38 AM |
| 14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 02:37 AM |
| Battery Replacement and Cold Cranking Amps | O. Sami Saydjari | Owning | 27 | February 2nd 04 03:38 PM |
| Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 02:29 PM |
| Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 07:32 PM |
