#11
Hi Eric:
No longer satisfied with the Nikon F duct taped to the wings? Here is an alternate approach to think about. Buy one or more miniature television cameras. These things can be tiny and inexpensive (some are no more than the size of a pencil eraser). Then mount one in the front of the sailplane and run a cable back to your palm computer and use the palm computer to record photos. You could have a camera in each wingtip and even one in the tail. Total weight just a few ounces. Switch cameras with a switch in the cockpit. Regarding the polarizing filter, it needs to be rotated for maximum effectiveness, depending upon the angle of the sun. If the filter is fixed, you may have to rotate the sailplane for maximum effect. Polarizing aerobatics, so to speak. Colin |
Eric Greenwell wrote:
I'd like to replace my current digital camera with one better suited to pictures from my glider, but I'm having difficulty finding one with the features I want. You'll have to check many different tipes on dpreview.com It will take a long time... I suggest you check: Nikon 8400, 8megapix, zoom 24-85mm Canon S80, 8MP, zoom 28-100mm Canon S70, 7MP " " " Canon S60, 6MP " " " Minolta A200, 8MP, zoom 28-200 and probably many others. The latest prosumer is the gorgeous Sony dsc-R1 (10MP, zoom 24-120), buti it won't pass through your canopy window for hand-held shots from outside. Aldo Cernezzi |
COLIN LAMB wrote:
Hi Eric: No longer satisfied with the Nikon F duct taped to the wings? Here is an alternate approach to think about. Buy one or more miniature television cameras. These things can be tiny and inexpensive (some are no more than the size of a pencil eraser). Then mount one in the front of the sailplane and run a cable back to your palm computer and use the palm computer to record photos. You could have a camera in each wingtip and even one in the tail. Total weight just a few ounces. Switch cameras with a switch in the cockpit. Poor image quality, unfortunately. Regarding the polarizing filter, it needs to be rotated for maximum effectiveness, depending upon the angle of the sun. If the filter is fixed, you may have to rotate the sailplane for maximum effect. Polarizing aerobatics, so to speak. I'll probably just hold it in my hand to try at first, then try it on the camera. Possibly one orientation might adequate, since the reflections on the canopy always come from the same place (the instruments), so sun position might not matter. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
I've had some good luck with a wing mounted camera using a Radio remote
control with a Harbortronics Digisnap 2200 controller and Nikon Coolpix 5400 digital camera. examples: http://www.ssa.org/sport/PhotoGaller...p?PhotoId=1026 http://www.ssa.org/sport/PhotoGaller...p?PhotoId=1028 http://www.chilhowee.com/DSCN0560%20e.jpg http://www.chilhowee.com/DSCN0565.JPG http://www.chilhowee.com/DSCN0567.JPG hardwa http://www.harbortronics.com/detail.php?id=19 http://www.harbortronics.com/ Their system works with a lot of Nikons and a few other brands. another option outside the US: http://www.jg-ic.com/jgrc1.html This would work with a Sony DSC-V1 or other Sonys with some cameras a systems such as this could be added to a radio remote http://wading-in.net/Remote.html regards, Chris |
2cernauta2 wrote:
Eric Greenwell wrote: I'd like to replace my current digital camera with one better suited to pictures from my glider, but I'm having difficulty finding one with the features I want. You'll have to check many different tipes on dpreview.com It will take a long time... I suggest you check: Nikon 8400, 8megapix, zoom 24-85mm Canon S80, 8MP, zoom 28-100mm Canon S70, 7MP " " " Canon S60, 6MP " " " Minolta A200, 8MP, zoom 28-200 and probably many others. The latest prosumer is the gorgeous Sony dsc-R1 (10MP, zoom 24-120), buti it won't pass through your canopy window for hand-held shots from outside. I've just been using dpreview.com, and it's a great site. It came up with the Canon S80, Fujifilm E510, and some way too expensive Leica, Ricoh, and Panasonic models. The S80 appears to do everything I want, and reasonably priced at ~$470, except I can't be sure the LCD is bright enough in sunlight. Probably have to look at one somewhere. The A200 and 8400 are better functionally, but quite a bit heavier and bigger. The prices are more, also, but not bad at about $150 more than the S80. I'll keep them on the list, just in case the compact camera idea doesn't work out. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
chris wrote:
I've had some good luck with a wing mounted camera using a Radio remote control with a Harbortronics Digisnap 2200 controller and Nikon Coolpix 5400 digital camera. snip Some interesting equipment, and perhaps the camera I pick for external glider pictures will have the inputs required. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Hi,
Nine photos! Paul Remde "chris" wrote in message oups.com... I've had some good luck with a wing mounted camera using a Radio remote control with a Harbortronics Digisnap 2200 controller and Nikon Coolpix 5400 digital camera. examples: http://www.ssa.org/sport/PhotoGaller...p?PhotoId=1026 http://www.ssa.org/sport/PhotoGaller...p?PhotoId=1028 http://www.chilhowee.com/DSCN0560%20e.jpg http://www.chilhowee.com/DSCN0565.JPG http://www.chilhowee.com/DSCN0567.JPG hardwa http://www.harbortronics.com/detail.php?id=19 http://www.harbortronics.com/ Their system works with a lot of Nikons and a few other brands. another option outside the US: http://www.jg-ic.com/jgrc1.html This would work with a Sony DSC-V1 or other Sonys with some cameras a systems such as this could be added to a radio remote http://wading-in.net/Remote.html regards, Chris |
At 03:12 08 December 2005, Chris wrote:
I've had some good luck with a wing mounted camera using a Radio remote control with a Harbortronics Digisnap 2200 controller and Nikon Coolpix 5400 digital camera. I have the same rig, but find the 5400 hs too much shutter lag and way too small an LCD for handheld shots. The new Fujis get great reviews for near-zero shutter lags and excellent high-ASA performance. Some have 2.5' LCDs. They don't have lots of manual features and I doubt they have remote shutter releases. http://www.dpreview.com/reviews/fujifilmf10zoom/ 9B |
Andy Blackburn wrote:
At 03:12 08 December 2005, Chris wrote: I've had some good luck with a wing mounted camera using a Radio remote control with a Harbortronics Digisnap 2200 controller and Nikon Coolpix 5400 digital camera. I have the same rig, but find the 5400 hs too much shutter lag and way too small an LCD for handheld shots. The new Fujis get great reviews for near-zero shutter lags and excellent high-ASA performance. Some have 2.5' LCDs. They don't have lots of manual features and I doubt they have remote shutter releases. http://www.dpreview.com/reviews/fujifilmf10zoom/ The Fuji models are quite attractive, but only two current models seem to have the wide angle (28 mm equivalent) that I want. The E500 and E510 have most of want I want and are priced well, but appear to have long shutter lag, no continuous or burst mode, and a 2" LCD monitor that is alleged to wash out in sunlight. So far, the Canon S80 seems to be the best fit, but I don't know for sure that it's LCD is any better (though it's bigger at 2.5"). None of them have remote releases, unfortunately, but I think this can accomplished with some tinkering, using a low cost radio control system for model cars/aiplanes. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
2cernauta2 writes
Nikon 8400, 8megapix, zoom 24-85mm I got one of these. Lovely camera, doesn't really fall into the small and compact category though. Sort of a stepping stone hybrid between compact and SLR. But it does hang on its strap quite nicely around your neck - just make sure it's secured against bouncing off your forehead in the event of a cable break if you launch on the winch! A link to some pictures taken with it using a polarising filter a couple of weekends ago over the Cotswolds here in the UK (not soaring - I was ballast in a motor-falke :-) http://j.domaindlx.com/scapegoatsanon/ -- Bill Gribble http://www.harlequin.uk.net http://www.scapegoatsanon.demon.co.uk "Consistency is the hobgoblin of little minds" - Emerson |
Refinish a Glider in Europe | Jim Culp | Soaring | 4 | November 19th 05 08:21 PM |
Aerodynamics of carrying water | Gene Whitt | Soaring | 54 | October 19th 05 07:24 PM |
Bad publicity | David Starer | Soaring | 18 | March 8th 04 03:57 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
I wish I'd never got into this... | Kevin Neave | Soaring | 32 | September 19th 03 12:18 PM |
