I tend to agree with Marcel. I also fly with an ILEC SN-10 and an IPAQ
with Winpilot. My sense is that algorith and precision from the SN-10 is always more accurate than Winpilot. The reason I say this is the same as what Marcel mentioned, which is the ILEC is capable of calculating windspeed and direction while in level flight, whereas most other software/computers require you to be circling. Respectfully, wrote: Doug, I'm curious to know how much variation you get between the two, if any. I use WinPilot Pro 6.x and an LX7000 Pro, and the two wind indications are usually very close. ~ted/2NO |
![]() As an aside . . . there are two versions of WinPilot, WinPilot 'Advanced' (all purpose) and WinPilot 'Pro' that **requires** one of the following devices to be connected to get accurate info: a.. Cambridge 302 vario/flight recorder b.. LX1600, LX 5000, LX7000, LX 160 c.. Westerboer VW921/922 d.. or a Borgelt B50 (with a gps-unit) (from http://www.winpilot.com/gps.asp) The **Pro** version is apparently able to derive wind info in straight flight as well as the 'Advanced' version's derivision from thermalling ability. jk wrote in message oups.com... I tend to agree with Marcel. I also fly with an ILEC SN-10 and an IPAQ with Winpilot. My sense is that algorith and precision from the SN-10 is always more accurate than Winpilot. The reason I say this is the same as what Marcel mentioned, which is the ILEC is capable of calculating windspeed and direction while in level flight, whereas most other software/computers require you to be circling. Respectfully, wrote: Doug, I'm curious to know how much variation you get between the two, if any. I use WinPilot Pro 6.x and an LX7000 Pro, and the two wind indications are usually very close. ~ted/2NO |
No, the ILEC SN-10 cannot compute winds in straight/level flight. In
fact, there is a known problem when flying long straight runs in ridge lift, where the wind speed drifts up to unreasonable values (like as much as double the true speed). It also tends to hold on to a higher wind speed when the wind dimishes. This can be big trouble when flying along a ridge into a becalmed area. When you turn around and then towards your field to land, the wind display updates, but by then it's too late. This is not a software bug per se, it is just a limitation of using GPS and airspeed to measure wind without a heading sensor. Adding a magnetic heading sensor won't really help, because the heading error is similar to the crab angle. So without a lot of calibration, you won't see much benefit, and you just introduce the possibility of greater error. A two antenna GPS would be a good solution, but the current consumer products are intended for marine applications, and are not set up to handle high bank angles. |
The problem mentioned below is not confined to the wind SPEED calculation.
Some months ago I flew a fairly straight ridge at 80 kts for many miles, with the SN10 telling me that the wind was straight along the ridge. I knew the calculated wind angle could not possibly be correct, because if it had been, there would have been no ridge lift to keep me airborne, nor would I have tracked along the ridge with the big crab angle between the ridge and the nose of the sailplane that was clearly visible outside the canopy. Eventually I made a couple of circles, after which the SN10 gave me a much more sensible wind result. Ray "Doug Haluza" wrote in message ups.com... No, the ILEC SN-10 cannot compute winds in straight/level flight. In fact, there is a known problem when flying long straight runs in ridge lift, where the wind speed drifts up to unreasonable values (like as much as double the true speed). It also tends to hold on to a higher wind speed when the wind dimishes. This can be big trouble when flying along a ridge into a becalmed area. When you turn around and then towards your field to land, the wind display updates, but by then it's too late. This is not a software bug per se, it is just a limitation of using GPS and airspeed to measure wind without a heading sensor. Adding a magnetic heading sensor won't really help, because the heading error is similar to the crab angle. So without a lot of calibration, you won't see much benefit, and you just introduce the possibility of greater error. A two antenna GPS would be a good solution, but the current consumer products are intended for marine applications, and are not set up to handle high bank angles. |
WinPilot offer... and UK news | Paul Crabb | Soaring | 2 | February 19th 04 09:22 AM |
Volkslogger, LX160 and WinPilot ADV | Michael Nyrup | Soaring | 1 | November 24th 03 06:21 AM |
WinPilot Offers Free WinPilot XP for your Desktop Computer | Richard Pfiffner | Soaring | 0 | November 8th 03 04:44 PM |
Declaring a flight in WinPilot to the Volkslogger | JohnD | Soaring | 0 | October 1st 03 11:55 PM |
Problem: Ground Speed Estimate with Volkslogger and WinPilot | RamyYanetz | Soaring | 3 | August 26th 03 03:06 PM |
